Question about Ricoh Aficio 1035 Copier
Sc 322 on a 2035. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont understand what a synchronization error is. whats the solution to this problem
  • Waleed Ibraheem
    Waleed Ibraheem May 04, 2015
    it could be because of
    • Laser synchronization board
    connectors loose, disconnected, or
    damaged
    defective
    • LD drive board defective
  • 29 Answers
The cause of the problem is toner leaking on to the laser unit. The easiest and quickest repair is to replace the laser synchronization board. Can try and remove the laser sync board and try blow it out with compressed air. I will admit this rarely works but its worth the try. There is a small lens in between the PCB and the black plastic housing. If you are brave enough you can solder the 4 points off and remove the PCB. Once it is off you will clearly see the lens and can literally wipe it clean with a cloth. Re-solder the PCB to the lens housing and reinstall in machine. This is a cheap fix that works and costs you nothing but time. Also replace the seals between the drum and developer unit to prevent toner leaking and contaminating the laser unit again.
Posted on Jul 02, 2016
  • 31 Answers
You have a bad laser unit ! Causes? The machine has not been well serviced at all, dust from paper and toner(a nightmare to tech RP men), have been accumulated in the poligonal laser motor, mirrors and lenses. Thus, the motor rotor is full with dust , refraining it to rotate at high speed (18.000rpm at least) or keep that speed steady (imperatif). The laser control board detects that and send that info to field tech. Sadlly, this should not happen with a periodic maintenance ( a real one).
A laser unit top A clean (and soft vaselin lubricationing laser motor rotor) may sometimes solve the problem, but to my experience, most of the times is just TOO LATE, the abrasive work took its toll, a brand new poligonal motor and board is the solution, expensive but worthing if the machine have all the other parts working good (ex. Drum,blade, fusing unit, developer etc).
So, next time you think the tech repairman is taking you a lot for periodical maintenance, (ahhh! it happens all world wide...) , think all that money you could save now! PS. this last words is not for you as a punish, gz!, just for all the other people reading this to have a notion how a simple 3 hour maintenance, whatever your currency is, can avoid repairs 10 to 15 times more expensive. Ive been dealing with this problem all my life. Ive been working with copier machines since 1985 , all brands colour and B/white,analog and digital. Im 57 and still working, aka ,still learning. You never know to much! Greetings.
Al (Portugal)
Posted on Jun 18, 2016
  • Ricoh Expert
  • 393 Answers
Try replacing the 3 door switches below the fuser, cheap fix. -Carl
Posted on Jan 03, 2015
  • Ricoh Master
  • 1,294 Answers
SC 322 - 1st laser synchronization error.Poor cable connection between the laser synchronization detector board and the LD unit.Laser synchronization detector board out of position and angle of reflection not correct.Laser synchronization detector board defective or LD unit defective.Try to change the LD polygon motor unit(90% defective).
Posted on Jan 02, 2014
2 Suggested Answers
  • 9 Answers
SOURCE: sc 322
Another poblem with this machine is that the sync detect for the 400 dpi and 600 dpi could be off. Go into service modes by pressing the yellow clear modes key then pressing the numbers 1 0 7 then hold done the red stop key till you see the display change. Now go into copy sp, then hit the 2 in the window {drum}, next use the page down button located in the middle of the screen till you see the one that says 2109 LD Beam Pitch Adjust. Go to number 2109-8 beam pitch data reset. execute then go to 2109-1 and set it to 144 then hit pound. Now go to 2109-3 and execute. last go to 2109-2 and set it to 168 then hit pound. Now go to 2109-4 and execute. exit out of the service modes window. now try to run a copy and a print. If these fail the you either need to clean the laser assembly, a polygonnal mirror moror or laser drive unit.
Posted on Dec 16, 2008
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
How can I correct error SC559?
Fusing Unit Third Jam Error (Fatal Error)
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
  • ? Afterthiserrorhasoccurredthreetimes,themachinewill shut down automatically and cannot be re-started until the machine has been serviced by a service technician.
  • ? Checkthepapertransportpathforanyphysicalobstructions (paper scraps, etc.)
  • ? Makesurethefusingunithasbeeninstalledcorrectly
  • ? Afterservicingthemachinetosolvetheproblem,theservice technician must execute a "Fuser SC Reset". Otherwise, the
    machine will continue to issue this SC code and cannot be operated. ( "Executing Fuser SC Reset")
Feb 19, 2016 | Ricoh Aficio SP 100SF e Laser...
Ricoh aficio SP4100NL error sc 546
Ricoh uses error codes in order to alert users that there is a problem with the functioning of the copier. Codes that begin with "SC" refer to issues with the fuser components, which heat up to bind the toner or ink to the paper. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified Ricoh technician.
Instructions
    • 1 Press the "Clear Modes" button. This button will be on the main panel.
    • 2 Press the "1,0,7" keys in succession. You do not have to hold the buttons down together but need to press and release them in this exact order
    • 3 Press and hold the "Stop" key. You will need to hold this button down until the Ricoh enters service mode. The touch screen display will say "service mode" and three soft keys will appear.
    • 4 Press the "Exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
    • 5 Turn off the main power. The main power button will be located on the side or front of the copier.
    • 6 Turn the power back on. Once the copier is powered back up, the service code will be cleared.
Jul 20, 2014 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
Sc 322 on a 3045. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont...
Oct 16, 2008 | Ricoh Aficio 1035 Copier
My problem with the Lexmark optra sc 1275
Lexmarks use a silicone oil cleaning pad on top of the fuser, try to locate a door on top towards the rear, take it out you might see a long black piece, when you take it out it has a felt on the bottom it is used to clean excess toner off the fuser it should be replaced everytime you change your toner ( usually comes w/the toner).
Oct 11, 2007 | Lexmark Optra SC 1275 Laser Printer
Ricoh Aficio 1035 Copier Logo
392 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
