Beko washing machine
Washing machine drum will not turn on any programme. It is a brushless motor, therefore not carbon brushes, nor it the belt broken. How can I tell if it is the PCB module or some other problem with the motor itself, please ? It is a 2 year old Beko WMB 81643LW. Thanks
  • john Dec 30, 2013
    when you say it is a brush less motor then why do people tell you to chane the brushes
    Master:
  • 367 Answers
Turn off power and check to see if fuse blown (for the motor) on the internal circuit board (if it has one). You will probably need to remove the cover. If you are lucky you might be able to turn the machine on its side to gain access through the bottom to any fuses ? Get help when lifting heavy objects.
Posted on Dec 30, 2013
SOURCE: beko washer
have you tried the brushes on motor
Posted on Jan 02, 2008
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
Posted on May 20, 2009
  • 57 Answers
SOURCE: Hi can you tell me how to change the brushes on my
If the motor in queston is a C.E.Set or Sole, you can do it by tilting the machine back against the wall. Otherwise, you'll have to take the back off and remove the motor by opening the bolts. Easy to change the brushes after that
Posted on Dec 08, 2009
SOURCE: How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Posted on Jan 17, 2013
My washer wont spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more Beko WME7247W test videos at site
Aug 08, 2014 | Beko WME7247W Washing Machine
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
Beko wma641w wont spin?
Hi if your beko wma641w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 24, 2013 | Washing Machines
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
May 17, 2012 | Beko Washing Machines
Beko washing machine wont go into full spin
Carbon brushes on motor need renewing. Not terribly difficult job. Be sure to disconnect from power before attempting.
Feb 28, 2010 | Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Aug 23, 2009 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
