Question about HP Pavilion Computers & Internet
How to coonect HDMI CABLE from CPU to Monitor of HP Pavilion
I got an HDMI cable with HP pavilion Desktop Computer. But there is no port for it on CPU. Can anyone tell me how can I connect the HDMI cable from monitor to CPU ?
  • Riyaz Ahmed
    Riyaz Ahmed Dec 30, 2013
    Sorry Jon, I could not find any HDMI port that fits the cable on the back of the computer tower (CPU)
  • 49 Answers
Look for an HDMI port that fits the cable on the back of the computer tower and monitor, also look on the video card outputs on the back of the desktop itself.
Posted on Dec 30, 2013
  • 62 Answers
SOURCE: Boot
Do any lights turn on when you power it on? Can you here the fans spinning and hard disk working?
Posted on Sep 14, 2007
  • 77 Answers
SOURCE: no audio/cable box to computer monitor using hdmi/dvi
Hi lauriesbc
if you take the audio feed from your cable box via the line out sockets then plug into line in on your sound card you shud be able to get audio.....
hope this helps
Posted on Feb 16, 2009
  • 112 Answers
SOURCE: unable to connect speakers to desktop
The monitor has integrated speakers. This means that there should be a headphone jack at the front or side of the monitor. You can plug your (amplified!) speakers into this jack, and it will bypass your monitor speakers.
Posted on Mar 26, 2009
  • 109 Answers
SOURCE: Are Dell monitors not compatible with older HP
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Posted on Jul 18, 2009
prodcali
  • 198 Answers
SOURCE: clicking noises coming from monitor with hdmi cable attached to computer have no problems with other connections that came with monitor
Try getting a video card, if not look for a new monitor.
Reason i say get a video card your motherboard is probably working to hard depending on how old your pc is. When getting the video card it takes stress off the board when monitor is plugged into video card.
Posted on Jul 23, 2009
How to connect the HDMI Cable from monitor to Computer which has no HDMI ports?
You need a purchase a new cable. I assume your HP pavilion is under 5 years old. And you should have a white DVI port in the back for a monitor. If you do have that connector, then all you need is a DVI - HDMI cable, make sure the DVI will be to the computers end and HDMI to the monitor.
for example this cable:
http://www.amazon.com/AmazonBasics-HDMI-Adapter-Cable-Meters/dp/B001TH7T2U
Dec 31, 2013 | HP Pavilion Computers & Internet
Need to connect hp pavilion vf15 monitor to mac computer
First of all, before you look which one to buy, you need to find out which Video Port does you Mac has, i.e. VGA or DVI or Mini DVI or HDMI. Once it's confirmed, you have to find out the same with your monitor, so that you can buy the appropriate cable.
Pictures Below:
1. VGA
2. DVI
3. Mini DVI
4. HDMI
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | HP VF15 15 in.
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
No cable and no sound on speakers for flat screen monitor
Hello Tothelake45,
When you bought your computer, you might have received lot of cables along with it... so find out the cable that has the jacks on both the ends of the cable. The Jack looks like that shown below.
So we are looking for a cable that has a jack at both the ends.. One jack goes into the soundcard of your computer (the green color coded port or the port where you normally connect your desktop speakers or headphones) and the other end goes to the similar connector on the monitor which is color coded as well (green color).
Please let me know if that works and please do not forget to rate the solution.
Thanks and Regards,
Srinivas
Apr 08, 2009 | HP Pavilion A6430F Desktop PC
Connection between computer and monitor!!!
The cable for the monitor has to plug into the desktop. So it's a VGA cord or DV Cord depending on the type of video card you have on your desktop. Some have a built in VGA port. Make sure you connect this to your desktop.
12_17_2011_8_16_49_pm.jpg12_17_2011_9_02_50_pm.jpgThis is the cable
Jan 09, 2009 | HP Pavilion M9040N Elite Desktop PC
Identify cable & where to connect to get audio on HP w17e monitor
male mini-stereo to male mini-stereo
Plug into LIME GREEN port on computer.
Dec 28, 2008 | HP w17e Monitor
Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Mar 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
