Question about Sanyo PLC-EF31N Multimedia Projector
Sanyo PLC EF31N projector will not power up. No ready or lamp light. Last used several weeks ago. Worked perfect. Now no power. Internal fuse OK. Small relay clicks when power switch turned on.
SOURCE: PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
Hey zrscott388, did you end up replacing the bulb and did that fix it? My Z1 is doing the same thing. I hate to spend 300-400 on a bulb and it doesn't work. The Z5 is going for 1100 new on Ebay. I rather do that than waste money. Please let me know.
Posted on Nov 12, 2007
dhiman
  • 115 Answers
SOURCE: Sanyo PLC XU48 problem starting
Service and reinstall main PCB connectors and cables including sensors. check the lamp condition also.
Viren
Posted on Nov 27, 2007
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
  • 3 Answers
SOURCE: Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Posted on Aug 23, 2008
SOURCE: sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Posted on Jun 03, 2009
My Sanyo plc xu70 projector lamp is brand new after replacing it still has the same prolem.when I turn it on the power light gets green for seconds then red blinks then it stops..what do you think the...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 17, 2014 | Sanyo Projector Lamp for PLC-XU70
My Sanyo plc su20n comes on but shutts off after a couple of minutes. Does not give a temp warning just ready indicator goes of and picture goes off. IF you wait a couple of minutes the ready light will...
check the physical nature of the lamp in the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause premature shut off.
Sep 14, 2011 | Sanyo PLC SU20N Multimedia Projector
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
Hello, I have a PLC XP45L. As soon as I turn on the projector it goes off. The only light on top of the projector is the READY light. We replaced the lamp last year and probably have around 50 hours on...
good day mr david, just clean the air filter of your projector, check all the fans if working... if this problem occur again your lamp ballast is defective.
jahting
Oct 29, 2009 | Sanyo PLC XP45L Multimedia Projector
Sanyo plc-xt10a will not power up. ready light is not on. power to unit is good.
First, check the lamp/lamp door--the door has a safety interlock that prevents power from getting to the projector. Make sure the power *is* getting to the unit by using a known-good power cord. Also, check the 3 air filters. If one or more was clogged with dust, the unit might have had a thermal sensor trip. There is also an internal fuse on the power supply which may have blown.When was the last time the projector worked correctly? Have there ever been any power problems related to that unit before? If the above checks yield no success, the projector will have to be repaired at a service facility. Hope I was of some help---Rick
Sep 09, 2009 | Sanyo (6103055602) Projector Lamp for...
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo PLC-EF31N Multimedia Projector Logo
163 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
