Question about VeriFone PCCharge Pro Full Version for PC
PC Charge pro 4.4 windows 98 (yes 98) we are getting an error 3022 (when authorizing or settling a card) it reads-The changes you requested to the table were not successful because they would create duplicate values in the index, primary key, or relationship......... We did not make any changes. We were told to try to change the transaction number by going into setup
  • 2 more comments
  • julie2880 May 19, 2009
    Wow thank you so much for your prompt response.
    I know a little about computers, but I am not that savy unless this is sounding more difficult then it is. I don't know how to found the table the form is bound to, to check which field is the primary key. How do I do that?
    If you can give me some idea on how to set the primary key tables to be an AutoNumber datatype that would be great.
    Thank you.
    I understand I have to change/fix the primary key. What I don't understand is how. There is nowhere in the pc charge pro software under setup that shows primary keys or tables or anything to allow duplication. or to give me any indication what the primary key is. There are tabs to repair and compact the database (which didn't work).
    So how do I know what the duplication is? How do I access this table?
    Can you help with these questions? Thank you.
    I do not have design view and I did not create the database so I do not know what field the primary key has been set. I guess I will keep looking for solutions.
    Thank you.
  • julie2880 May 20, 2009
    Chris
    Thank you for your help. After looking at this and trying to resolve and unfortunately getting no support from pc charge because the software is so old, we decieded that we might make a back up of the old database and just create a new one because there is this feature in the software (not really sure yet). It might be a lot of hours entering all our information but it looks it might be the best solution until we are ready to upgrade$$$ to a whole new system.
    Thank you.
  • 31 Answers
Yes the last solution is correct. In detail the version you have is 1 NON Compliant and you can get your merchant account account down and 2 the harsher one is fined for not using current versions.
I would recommend a New cost effective computer with windows xp or xp pro then the new version of software is roughly around $240 and $270 depending on how much commision your provider wants to make. Or run the cards via an online gateway such as www.greenlightpayments.com.
Reason being that the older versions stores card holder data if your computer gets hacked you are held accountable for each fraudulent trans that happens on your customers cards.
READ THE FINE PRINT OF YOUR MERCHANT OPERATING GUIDE.
Posted on Jul 14, 2009
  • 696 Answers
although like every other expert on this site I'm a bit rusty on any POS solution for 98, I did spend several years working in hotels using similar systems.
For a quick review when you tried to set the numbering routine you likely picked a number which had already been used in the database. Assuming I've got that part right, short of being able to open, understand and edit the database there is no easy solution that could be resolved through simple forum advise.
That being said you've been at this for more than a couple hours now and obviously we're all too rusty to guide you through "blind". The simplest solution in this case and likely the fastest would either be to send the database file to PC Charge for correction assuming they're even still in business or to restore yesterdays backup and simply re-enter all of todays transactions to update the database properly. The only drawback to this is, if my memory serves, PC Charge will attempt to reprocess duplicate billings as you re-enter.
Since the problems I was dealing with prior to Y2K most systems have built in reconciles that watch for this activity and remove the duplicates, but you may have to manually adjust the entries or even ring them through as cash and make the correction in your GL once your done for the day to avoid the duplicates.
Needless to say the fastest way to resolve the issue is simply restore yesterdays backup file, role the date ahead to today and re-enter the days transactions(cash method or otherwise).
Let me know if this will work for you, if not I'll try to shake off a bit more rust and find another solution.
Chris
Posted on May 19, 2009
  • Chris
    Chris May 20, 2009
    Yup,
    I've worked through this decision with lots of people on lots of ocassions. If you don't plan on spending the money for a new version it seems the restore and re-enter option will be the best. I have seen a lot of people upgrade over the years though just to get out of todays current jam.
    Won't fault you for either decision, they both have good reasoning behind them.
    Good luck with the re-entry,
    Chris
    Brigadier General:
  • 3,614 Answers
Your primary key has to be unique, and that's why you are getting the error as you are trying to enter a primary key value that already exists in your table.
Check the FF:
  • Take look in the table your form is bound to and check which field is the primary key, then check which control on your form is bound to that table field.
  • When you're trying to enter a new record, that's the field that will be generating the error if you've entered a value that already exists.
Generally you're better off setting the primary key of your tables to be an AutoNumber datatype which will get rid of your error. You can set your current PK to Indexed (Allow Duplicates) in the table field properties.
Let me know for further clarificatiuons
  • micromaster
    micromaster May 19, 2009
    Just change the field properties, for not preventing the PK to duplicate.
    Hope this initial info/idea helps. Kindly rate this solution
    Thanks.
  • micromaster
    you can access it on the design view options. just select the field name that you have set the primary key. you have to options set it Autonumber / with duplicate enable.
2nd Request! when I try to run 2011 card games I get a message which reads " Problem was detected with your license file. Would you like to recover now?" YES NO -- I hit 'YES'. A window...
Sorry Gary, but your problem is being listed under Bicycles--
Not many of us Bicycle Mechanics are much good with electronic games!
Try re-listing under Bicycles-
Let me know if I can help.
Mack B
Jan 28, 2011 | Cycling
Need to do a credit card refund for RPE
If you can recall invoice and you have not yet batched/settled your cards, just void the invoice and it will refund the amount to the card.
If you have settled the cards and cannot recall invoice, ring up a sale to a non-inventory item, do a price change to the negative amount of sale, and then charge this to the card. It will refund this amount to the card.
Make sure security settings will not let your employees ring up negative amounts or they could start refunding to their own card.
May 30, 2010 | Pc America Restaurant Pro Express
No mac driver?
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Dec 21, 2009 | Logitech Webcam
I have just bought this webcam for my mac but seems unable to set up
A. Skype Setup:
B. Yahoo Setup:
Dec 20, 2009 | Creative Labs Live! Cam Notebook Pro...
Error when scheduling a task
I came up with a temporary fix by changing the Run as: from "Toshiba-ea\Toshiba" to "NT AUTHORITY\SYSTEM". This allowed me to schedule the tasks accordingly. Note that I still do not know the password for Toshiba!
Oct 27, 2009 | Computers & Internet
Received an error message at close out RB00546E... Tech support tells me that my comuter operating system is too old to contract. Tell me to upgrade. Have a new computer coming Windows7. In the meantime,...
Would probably need the the entire error. The RB simply stands for Rejected Batch when you are trying to settle (I'm guessing with Vital/TSYS). the 00546 is the transaction number. This looks like a rather large batch. The transaction in question is the 544th transaction (the first two records to go over in the batch contain account information and your company information. So always subtract 2 from the number shown).
Without seeing the rest of the error, I can't say exactly what is wrong with the transaction. There should be a 3-4 digit number after the E in your response from the processor.
At any rate, depending on your version of PCCharge,there is a Batch Editor is included. It will be in (C:\Program Files\Active-Charge) for Payment Server or (C:\Program Files\PCCW) for Pro, and is named BatchUtility.exe. This will allow you to quickly view the batches and edit the transactions you need.
If Vital/TSYS is your only merchant account, then your batch will be named Visa1.xxx.Since it is now a rejected batch, it will be called Visa1.PCS (A regular batch should be Visa1.ENC for encrypted. Unless you are on a really old version). You should be able to open the Batch Utility, Open the bad batch by clicking find "Indeterminate" button, find the 544th transaction (if it's corrupt, you'll be able to find it rather quickly), and void it out. Keep in mind that this is not the same as voiding through the inteface, it is merely taking the transaction out of this particular batch, not voiding the transaction authorization. If it's a sale, you're authorization code will still be good (assuming it hasn't been over 30 days since you last settled). If it's a credit or void, there will not be an authorization number to worry about, and you can just dump the transaction altogether.
Make sure to take notes on the transaction so that you can run it as a post-auth (if it is a sale) after your batch is accepted. Once the offender is removed, you should be able to go back into PCC and settle as normal. You will get the message about "all indeterminate batches need to be closed first, blah blah blah", click "ok", check your totals and then attempt to process the settlement.
Good Luck and hope this helps.
Oct 16, 2009 | Go Software Inc. PCCharge Pro...
I cannot install dynex wireless card on windows 98 I keep getting an error unable to load
Have you checked if the drivers you have downloaded are meant for Windows 98?
Did you check if there are compatible drivers available for Windows 98?
regards
Sandeep
Oct 11, 2009 | Intel Pro 1000XT Server Adapter...
Getting error # 3022
Hi Julie,
You shouldn't really be using that version anymore for several reasons. However, since I don't work there anymore, and I'm sure you have your reasons for sticking with it ...
There is a way to purge the transactions, although Tech support will tell you that it is not recommended (not to mention, there's nobody there anymore that was around when 4.x was out.). If you're just wanting to clear out the old files and start new so that your database is smaller, there is a rather simple solution. If you still have your original pccharge setup cd, there is a blank database on the cd. Make sure all current batches are settled. Rename the current database to something that will make sense (perhaps with a date of the last transactions in the database). After that database has been renamed, you can copy the blank PCCW.MDB from the cd to your PCCharge directory. Once the database has been copied, right-click on the database to make sure that it didn't get marked as read-only during the copy & paste. This will start your transactions from a fresh database. Your history will no longer be available from the software however. (If you really need that history you can temporarily rename the old database back long enough to pull the history and then switch back to the new one). After this, start up pccharge and go to setup numbers and synchronize numbers with troutd. You should be good to go after this.
May 19, 2009 | Go Software Inc. PCCharge Pro...
Installing Buffalo Webcam on Mac
Hope this helps. Bud
Mar 22, 2009 | Computers & Internet
Nokia pc suite
Uninstall every BT software you have and any Nokia PC Suite software you have. Plug in your BT phone dongle and let windows auto recognize the device. after it is done installing, then put in the Nokia cd. Do it in this order.
Nov 11, 2008 | Nokia E71 Smartphone
VeriFone PCCharge Pro Full Version  for PC Logo
131 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
