Question about Refrigerators
Can you change a seal on a freezer if the seal is built into door ?
  • Refrigerators Master
  • 10,291 Answers
Of course you can
Posted on Jan 17, 2014
5 Suggested Answers
  • 12 Answers
SOURCE: Kenmoor Refridgerator-# 970-69823C freezer door hanging
replace hinges or the screws for the hinges with slightly bigger screws.thaw out the fridge outside check and reglue the seals with goop glue.let dry completly before reuse adjust the humidity to low ( if possible)or dont have it on so cold to prevent a rehap.
Posted on Nov 09, 2008
bobicehouse
  • 1524 Answers
SOURCE: Need to replace freezer door seal on Hoover HFA29K
This is probably a "push in" gasket.
Posted on Apr 23, 2009
Maytag317
  • 1136 Answers
SOURCE: Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
Posted on May 23, 2009
philbran
  • 242 Answers
SOURCE: changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Posted on Jun 10, 2009
Why is my freezer not cold enough?
Check the freezer door seal is not leaky. Look for signs of moisture condensation along the door. Apply a thin film of Vaseline along door frame. This will make door seal stick better.
Also check there is no ice building up in freezer. This is a self defrosting fridge and built up of ice inside means warmer temperature. Lower the use of ice cubes from the ice maker to reduce load on compressor as this can effect freezer temperature.
Check freezer is not full of too many items causing reduction of air flow and hence reducing cooling effectiveness.
May 01, 2014 | Kenmore Refrigerators
Electrolux Built in freezer door not closing.
I'm suspecting the door also because of the lack of suction power. you have to check the gasket more. Frost around the door is a great indication of where warm moist air is coming into it.
Aug 14, 2013 | Refrigerators
Ge monogram 48 built in refrigerator
If the seal to the top freezer is not sealing properly, this could be a matter of door adjustment. This a common refrigerator/freezer problem. The correction consists of loosening the door hinges and adjusting the seal for eveneness then retightening the hinges
Jun 27, 2013 | Refrigerators
Frost developing around door of freezer in my ss built-in ge refrigerator
look for a mullion heater switch and turn it on, this heats the door frame and does not let it get so cold, it could also be called an Economicle switch or an exterior water control switch
Mar 05, 2012 | GE Refrigerators
Evry six months to a yr our upright freezer has frost built up inside. What can be the probable cause?
Two things will cause this assuming the defrost timer is working or the frost would be every week. The door seals are not sealing somewhere and a lot of humidity is getting in.
Jun 16, 2010 | Freezers
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Condensation build-up on the bottom seal of Viking freezer door
I have seen this before and it goes beyond the seal, if it was the seal, you would see vapor trails around the area where the seal is leaking. You may have a breakdown of foam in the door. How old is it?
Jun 17, 2009 | Viking 42 in Built In Professional...
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
