Question about iPhone Apps
My kobo wont turn on
My kobo won't turn on. I put the charge on and the screen went blank. Charged the unit and there was nothing but a flashing green light. Turned the unit off and when turned back on the Green Light flashed, then the blue light flashed and then the green light keeps flashing and the unit will not charge or come on????
  • Jon Hill Dec 30, 2013
    Hi Jeanette , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Have you let it charge by itself untouched for 24 hours?
  • Jeanette
    Jeanette Dec 30, 2013
    Yes I have tried to charge it for longer than 24 hours untouched and still there is nothing on the screen!
  • iPhone Apps Master
  • 652 Answers
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Posted on Dec 11, 2017
1divebum
  • 12 Answers
SOURCE: Sony KV-32HX15U Flashing standby light
did you ry to unplug from the wall for at least 3 min then plug back in if that does not work try pushing the tv button and reset at the same time on the remote for 1 min if this does not work please take it to a repair center
Posted on Sep 23, 2007
  • 8 Answers
SOURCE: no 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Posted on Jan 29, 2008
  • 208 Answers
SOURCE: lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Posted on Feb 05, 2008
s4u311
  • 813 Answers
SOURCE: hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Posted on Jul 16, 2008
heatman101
  • 43501 Answers
SOURCE: ice maker not working flashing green
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dfdf
Posted on Sep 30, 2010
My Kobo Aura HD's comfort light is off and I can't find a way to turn it back on.
On the top of the e-reader, to the left of the on/off slider (looking at the screen) there is a push button on/off switch for the light. Once the light is turned on (and there is a 'star' symbol on the screen, the brightness can be adjusted by touching the 'star' and using your finger to slide the brightness control).
Mar 19, 2015 | Kobo Aura HD E-Reader
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 | Kobo Arc
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
Ds is charged but screen wont turn on
There is most likely worn wiring from your control pad to your screen or you have a burned out screen. This really is not much different from a lap top in this sense and should be fixable if you can find a new screen to put on it.
Oct 07, 2012 | Nintendo Video Game Consoles & Games
My touch screen kobo reader has stopped working
Make sure the Kobo is fully charged and switched off. Hold down the 'HOME' key while turning the Kobo on. When you see the power light release the 'HOME' key. The lights will flash. Follow the onscreen prompts.
Jan 06, 2012 | Kobo eBooks by Kobo
My lookbook won't turn on
Try letting it have a full charge. Occasionally this is the problem with a black screen. If that doesn't work, call kobo. They should replace your lookbook with little trouble. Just be patient if you go this route, it takes around a month to get the replacement, and the replacement is a refurbished unit as a heads up. Personally, I was more than happy with my replacement. No more problems! :)
Sep 03, 2011 | Sharper Image Literati Reader 16375680042...
Phone went dead. charged it. charge complete. wont
try taking battery out for 30 seconds,then put back in!?
Oct 18, 2009 | Cell Phones
Only charges... nothing else works on my Samsung
It should be fine to call when the phone is charging. It could be that the phone was "sleeping" as it charged and then the sudden energy draw of the phone call while it was charging screwed up the battery. I think you should take it to the shop.
Aug 23, 2009 | Samsung SGH-d807 Cellular Phone
Psp wont come on
that is what happens to me i put graf theft auto libery city stories in my psp i turn it on the green ligh come on and it just sits there with a blank screen
-TIM pleas help
Dec 25, 2007 | Sony ACY-BR81/OB
iPhone Apps Logo
308 people viewed this question
Top Apps Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
