Question about Azpen Tablets & eReaders
My tablet has a blank blue screen what is the problem
Why has my acer a3 screen gone blank ?
The program of your unit is wiped out. reprogramming is the solution.
Jul 27, 2014 | Acer Iconia A3 10.1 Tablet - 16GB
Why Is my kocaso tablet come on but blank back out?
I have the same problem with my KOCASO M9100 9" Black. I can tell it had power by the small LED inside that is blue when on but not plugged in, purple when on and plugged in, etc. But my screen is not working, I don't even get a hint of light from it on boot, and my computers cannot find it 95% of the time, the other 5% it detects the tablet as "Unknown Device", then when I click on the Device, it says its either disconnected or turned off. Cannot find a solution!
Jul 06, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Blank screen on tablet
blank screen working fine this morning but can hear sound
Jan 16, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Fijutsu T4210 it is on but screen is blank.
Hi, it is possible that the Ram may be faulty,or the Screen so to confirm,connect external monitor to the VGA port(Blue in color) and also check each RAM chip one after the other to bring out the the faulty one.
Jan 25, 2011 | Fujitsu LifeBook T4210 Tablet PC
I have upgraded my tc1100 to 1.5Gs of memory. The description on the memory module is ( Super * Talent D400SBG/H STT DDR-400 PC3200 SO-DIMM Hynix 1G/64X8). The problem is the computer initially boots into...
It sounds like that memory should be compatible with your tablet PC. It may be a bad memory stick -- try to replace it with a different memory stick (preferably from a different manufacturer) and see if it still gives you the same problem.
If you didn't have this problem before you installed the new memory, a different memory stick will likely correct the issue. You can also try removing the new memory and see if the PC boots up like it should.
Dec 08, 2010 | Compaq tc1100 Tablet PC
Blank screen on laptop
Maybe the OS is corrupted, try to reinstall the OS
Jun 24, 2009 | Compaq tc1100 Tablet PC
Tablets & eReaders Logo
Top Azpen Tablets & eReaders Experts
 Mikey
Mikey
ray gallant
Outback Jack
Outback Jack
Are you an Azpen Tablet and eReader Expert? Answer questions, earn points and help others
