Question about Hotpoint UY46 Style Line Stainless Steel Electric Double Oven
Hotpoint bd32 main oven not heating - Hotpoint UY46 Style Line Stainless Steel Electric Double Oven
barkencoa
  • 3463 Answers
SOURCE: Hotpoint BD32 element not working
Assuming you are talking about the fan oven element, you should be able to feel heat from it , if you are not sure it is working, then you need to remove the rear cover of oven to expose the fan and the element, run it for a couple of minutes, then feel if it is hot, if not, it needs to be replaced.
Hope this helps.
Posted on Nov 27, 2009
  • 1891 Answers
SOURCE: hotpoint uy46 main oven over heating please
replace the tempt prob as if the control was bad the other oven would not respond . there is probe in each oven to tell the prosser what tempt they are running at . if one prob failes no info is sent to the prosser . ( replac it mm .. )
Posted on Dec 28, 2009
barkencoa
  • 3463 Answers
SOURCE: the main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Posted on Feb 22, 2010
barkencoa
  • 3463 Answers
SOURCE: I have a Hotpoint BD32 double oven. The top oven
You need to replace the oven element,, located at the rear of the bottom oven compartment behind a removeable panel.
Posted on Oct 03, 2010
  • 22 Answers
SOURCE: My Hotpoint electric oven no
HI, seen this before with the ge/hotpoint elec. ovens i worked on when i did apartment maintenance. One could be a bad control switch(knob u turn to turn on oven).turn on broiler and see if it comes on,if it does not that could be it.If it comes on it u might have to replace lower element,but could still be control switch not working for that section.But it will one or the other.
Posted on Mar 12, 2011
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
Hotpoint BD32 timer does not work
The timer may be defective.
Dec 23, 2017 | Ovens
Hotpoint bd32 oven and top oven/grill what output does this have .and does it need 6mm cable connection or can it go on a plug
Hi.
You most definitely need a 6mm hard wired supply cable to cooker, anything less, and the cable will overheat .
Under no circumstances connect it to a 13 amp suupply and plug.
The total kw output can reach in excess of 4-5 kw, so it is imperative that you hard wire it to a seperate fused supply.
Jun 22, 2011 | Ovens
The main oven of my DY46 Hotpoint is not heating up
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Hotpoint BD32 element not working, How can I check if it is a faulty element
Hope this helps.
Nov 27, 2009 | Hotpoint Ovens
Cannon Cambridge Double Oven. Main oven not heating up
Problem solved, Turned out to be the flame fail device. Next problem was sourcing part. Turns out that allegedly Cannon is now owned by Hotpoint so sourced part through them
Nov 24, 2009 | Ovens
Hotpoint oven heating element
check stat not open circuit and check selector switch not damaged
Aug 20, 2008 | Smeg SE250XUK Stainless Steel Electric...
Hotpoint UY46 Style Line Stainless Steel Electric Double Oven Logo
57 people viewed this question
Top Hotpoint Ovens Experts
ashburton
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
