Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C0991 error on bizhub c350 - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,696 Answers
The third paper draw
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 04, 2016
rylee_smith
  • 8619 Answers
SOURCE: COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 21, 2009
  • 15 Answers
SOURCE: malfunction detected error code c 001a on minolta bizhub c350
Im thinking either it was moved improperly and the image units werent kept level, or maybe just sitting to long caused them to settle in. try (gently) removing the IU's and shaking them (keep them level) in order to unclog or redistribute the developer inside. (imagine sand in a horizontal tube. It has to be uniform all the way accoss the tube, and not settled into any one location)
Posted on Jun 09, 2009
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
firecontrol7
  • 6696 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
  • 158 Answers
SOURCE: Bizhub C350 gives error code C-OF36 while making
that code means low toner density in the black developer unit so you either have a failed pwb mc board or a failed black toner motor
Posted on Oct 15, 2009
check the gear assy behind the front cover of the bottom draw
Dec 30, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
I ave problem on c350 error code 2160
BIZHUB C350 SHOWING ERROR CODE C-0900 AND
NOW C-0950
Sep 30, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 25, 2008 | Office Equipment & Supplies
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
