Question about Vtech Musical Bubbles Octopus
Octopus won't blow bubbles - Vtech Musical Bubbles Octopus
Octopus box what do I need to use it
If I'm reading this right you have an octopus which is a second emergency regulator for your buddy if he is in trouble. Where the original regulator hooks to the valve that goes on your tank ther should be a blank with a screw in it . This is where the octopus screws in . You will have a rubber o ring in side. Put it on the end of the threads from the octopus hose and insert it into the hole the screw once occupied.. The screw is just there to fill the blanks hole and can be thrown out.
Apr 13, 2018 | Scuba Diving & Snorkeling
What is spanish octopus?
That is the octopus caught off the coast of Spain (you did know that Spain has a lot of water along its coast).
Feb 27, 2015 | Cell Phones
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
Im running win7, and it does not recognize this device which is a usb hub 4 port
A lot of times it won't recognize these devices until you plug something into them. Have you tried plugging in a flash drive, printer, etc to see if it's recognizing it but not showing it?
Jul 19, 2011 | Eforcity 4Port Octopus USB 20 Hub Black
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My Mares Prestige S octopus is leaking air under water from the mouthpiece in as low bubble rate. Shoud it be ajustued and how
It may be that you have picked up a little bit of sand or grit, give it a good vigorous wash in the bath. Often octo's get dragged along the bottom and get rubbish in them. If it does need adjusting I strongly recommend you get a professional to do it. :)
Oct 25, 2010 | mares PRESTIGE 12 REGULATOR Scuba Gear
Smell of octopus in freezer
well wat u will have to do is clean the entire freezer out
with warm soapy water
then put a bowl of vanilla esence in there for a while
Jul 19, 2008 | Carrier Beverage AirĀ® CRD5GE-1W-G...
Vtech Musical Bubbles Octopus Logo
19 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
