Question about Sony CDX-L480X CD Player
No instructions on tuning radio
Have just bought a car with Sony CDX-L480X radio fitted. No instructions regarding tuning radio. Can you help, please?
The Manual is downloadable from Sony at
http://pdf.crse.com/manuals/3247340121.pdf
Avulon
Posted on Aug 08, 2010
I have a Sony CDX L480x fitted in my car, this radio has worked fine since i got the car, unfortunatly when i put the face back on it the other day, none of the buttons will work, volume, source...etc. All...
It sounds like the volume button may be jammed or the volume up switch may be bad. If the switch is open just enough to let some voltage through it locks up the microprocessor. Unless you have a multimeter and know how to check resistance on a switch you would be better having a professional repair person check it out.
Sep 29, 2011 | Sony CDX-L480X CD Player
I would like to fit the cdx-L480X into my caravan
ok that will work fine please tell me what the problem is genrally if ir caravan had a tape player the plug should be the same as this unit uses a uni plug if not there will be a converter for under 5 pounds
Jan 19, 2011 | Sony CDX-L480X CD Player
Hello! My Sony CDX-L480X car radio can't read the CD-s. Could somebody help me to solve the problem?
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning ,then the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence it could reject but the best is do a cleaning manually of the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Nov 27, 2010 | Sony CDX-L480X CD Player
Sony cdx-ca850
If you only get 1 station no matter what station you tune into, you have a ans electrical problem on the main board of the radio. Your tuning voltage is not changing as you tune thru stations. There is most likely a shorted or open transistor that supplies the tuning voltage on the main board.
There is no easy fix for this, you would need the schematic to find out why the tuning voltage is not changing.
If you know how to do electronic troubleshooting and have a multimeter and the schematic you can fix it with not to much trouble. If this is not the case, you will need to take it in to a service center.
Sorry that there is no easy fix for this problem.
Jun 17, 2008 | Sony CDX-CA850X CD Player
Honda Odyssey radio
chek connection on radio if not check the number behind the radio and call the dealer for the code if it work good if not simply go to a shop they probably broke the radio good luck cheers
Dec 30, 2007 | Sony CDX-L480X CD Player
Sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
Sep 08, 2007 | Sony CDX-M8800 CD Player
Sony CDX-L480X CD Player Logo
246 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
