Question about Garden
I have a craftsman 12.5hp riding mower. went to mow and a very loud noise came from the mower. sounded like i ran over a huge piece of metal. i had shut everything down and it would not start up. there was nothing caught in the mower deck. then the starter fried and i bought a new one. when that turned over, the same noise came from the mower. i had stopped to ensure i didnt fry another starter. i dont know what it could be.
  • 2 more comments
  • w1234will May 19, 2009
    does not have a pull start but i am able to turn the flywheel. did not seize up as far as i know.
    the flywheel does move freely. the blades do move, the problem starts before i engage the blades ( i have to engage the blades manually). when the starter contacts the flywheel there is a huge clanking noise and it starts to shut down. could the cam shaft or something like that be out of whack?
  • LeeatCSE May 11, 2010
    You say it burned up a starter. Is the engine turning over at all? Is this a mower with an electric PTO to engage blades?
    Will the engine turn by hand?
    Sniper:
  • 57 Answers
Since the flywheel rotates freely, are there any noises when rotating it by hand? If not, problem is likely not internal. I would suspect the starter or flywheel. Take the engine cover off and inspect the flywheel teeth. Mower can also be cranked with the cover off to see if all is working properly.
Posted on May 19, 2009
  • 148 Answers
I would check to see if you can rotate the fly wheel by hand. Also check to see if the blade(s) move easily (with the mower off and key out get under tractor and try to rotate the blade if it moves freely then great if not then you have other issues). Report back so that we can go from there.
Mike
  • Mike McDowell May 20, 2009
    Check the starter teeth to see if they are grinding with the teeth on the flywheel. My guess is that your starter is just a little off and the gears are meshing.
My craftsman ys4500 21hp riding lawn mower cranks but won't fire and I have tried everything
Have you pulled a plug and checked for fire? There is a huge difference between crank and no fire or crank and no start. If you have spark, make sure air filter is clean. Next step make sure you have fuel to the carb. After that the carb would be the next step. Have it cleaned and rebuilt.
Jul 18, 2016 | Craftsman Garden
I have a craftsman 48" riding lawn mower and when I was mowing I ran over a piece of rope which got stuck around the spindle. I have tried to remove the rope but am not having much luck. Is there an easy...
There is usually no easy way as the rope goes really tight, The best thing is to use an old bread knife with a wavy edge to cut it off.
The hardest thing is getting to it, if you are up to removing the deck and turning it over, that is the best way.
Aug 22, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Loud bang, hole in motor
Sounds like you threw a rod. If your warranty just ran out you might be able to get sears to still honor it.
Jul 14, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Jul 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
