Question about HP Officejet Pro K850 InkJet Printer
Printer lid open light is coming on when printer lid is closed
Printer cover open light keeps coming on when the printer cover is closed
  • HP Master
  • 419 Answers
The printer lid error can appear if any of the following are true:
- top lid is open
- rear duplexer or flat panel is not installed correctly
- cartridge bay area door is open
All of these conditions are detected by a series of sensors or circuits in the printer design so with regard to the lid and cartridge bad door you need to make sure that nothing has broken off that closes the switch.
I'd lay odds that it's most likey the rear panel/duplex unit. I'd recommend taking this out as per the manuals instructions and then reinserting it, carefully so that it fits in place properly.
Hope that solves your problem.
Martin
Posted on May 19, 2009
I changed my ink cartridge, and now it has cover open displayed but the cover is closed
when you open the lid there is a small white piece of plastic witch should be attached to a very small micro switch .this keeps coming off for some reason .you have to find it and reattach it to the switch that is just right of the middle of your printer .hope this helps
Oct 02, 2010 | Lexmark X3480 All-In-One Printer
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
Mar 01, 2010 | Epson Stylus Photo R320 InkJet Printer
Open Door
Hi, here is something that you can try http://bit.ly/bHHnnO
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Orange ink light keeps flashing and printer won't print
hello,
To correct this problem, unlock the carriage from the printer‘s capping station.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
  8. The printer should print the alignment page.
  9. Print from another application.
    thank u
Jul 29, 2009 | HP DeskJet 920c InkJet Printer
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid.
Geezer Geek
May 20, 2009 | HP DeskJet 6840 InkJet Printer
Cannot get to reset
there is a sensor in the printer that goes down when you close the cover that sensor is either moved from its place or got broken.just tab the sides of the printer little hard and checkout many times it comes in the position due to tapping it.
thanks.
Nov 22, 2008 | Lexmark All-in-One Printer with PictBridge
My printer keeps saying Cover Open and won't let me do anything else
Hi All printers have a protruding piece of plastic on the cover / lid, when out of place it tells the printer the cover is open
When you close lid it is inserted into main frame which tells the printer that the lid is closed.
Look for this it may be damaged. If so roll a small piece of paper and insert ito the recepticle hole.
It will trick printer that the lid is now closed.
You will need to remove it each time you need to change inks etc...
Good Luck!
Tinteiros (Ebay)
Jun 02, 2008 | Lexmark Office Equipment & Supplies
Printer is on but cannot print
if your power light is off and the paper and ink lights are flashing try this.
1. remove all the paper,
2. open the cover and check for paper jam
3. make sure the ink cartridge lid is securley in place by opening and re closing the ink cartridge lid
reclose the lid, disconnect the power supply and hold the power button for 30 seconds. reinstall the power plug and turn the printer back on.
hope this helps
May 12, 2008 | Epson Stylus® Photo R2400 InkJet Printer
Canon MP600 printer
sounds like the inner cover is not seating properly. so, perhaps there is something amiss inside, making that cover not latch cleanly? do a visual inspection(got one of those dental type mirrors?).
Mar 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
HP Officejet Pro K850 InkJet Printer Logo
383 people viewed this question
Seeker5211
Seeker5211
