Question about Hunter Mechanical Heat & Cool Thermostat 40135
Underfloor heating wont stop running
I have wet underfloor heating in one room controlled by a milux chronostat. The pump keeps running irrespective of temp set, programme, and water temperature. It doesn't even stop when switched off at the controller. The only way to stop is by removing the front cover of the controller.
  • Hunter Master
  • 10,137 Answers
Look for a stuck relay that controls the pump
Posted on Mar 29, 2014
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
Need wiring diagram to include: Underfloor heating downstairs (wet system,polyplumb) combi boiler for the heating and hot water
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
Oct 30, 2008 | Honeywell Heating & Cooling
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Home comfort protection plan
Direct Energy knows that maintaining your Texas home is essential to your family's well-being. You can't afford to put off protection until disaster strikes, so we've created protection for your home's electrical, plumbing, and heating and air conditioning systems.
Our home protection plans deliver security by combining preventive and repair services for your home's most fundamental systems, including:
Electrical wiring
Plumbing lines
Priority scheduling with us for all appointments
Surge protection
Heating and cooling systems
Our home protection plans remove the anxiety of unanticipated costs, while our certified technicians are ready to assist you with respectful, professional service and high-quality equipment. Because we view the money you spend on home service improvement as an investment in your home and your comfort, we're committed to helping you make it worthwhile. You can choose from our plans for Heating and Cooling systems, Electrical wiring, and Plumbing lines. Direct Energy's Repair & Maintenance Essentials Plan provides annual features to catch small service issues before they become critical, $500 insurance for every repair job*, emergency customer support any time you need it, service visits with no charges and no deductibles, and so much more.
if you want protect your roof leaks so you can apply EPDM Coatings :
Watch Corporate Video
Jan 20, 2014 | Audio Players & Recorders
I have a rehau ct room thermostat but don't know how it works - the time needs altering. In another room I have a rehau ta and I think the two work together to control the underfloor heating. Can you tell...
Please click on the below link to download the REHAU Technical Manual.
http://www.rehau.co.uk/files/8179_REHAU_BA_Controller_864602_UK.pdf
To set the WLCT (Time and Temperature control) for the system please refer to page number 45 (Section 10: CT Set up Guide).
Jan 21, 2011 | Heating & Cooling
Have RHOSS heat pump showing E01
Different manufacturers use different codes, as I am sure you have figured out. Most of them that I have run into E-01 means the inside and outside units are not communicating. One is without power or there is a broken or loose wire.
Jul 17, 2010 | Heating & Cooling
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Back up electric heater required.
A bit late for you probably Steve, but other browsers might be interested...
Micathermics are faster to warm up the room than other resistive heaters, but otherwise they're no more efficient - so it depends whether you feel that the fast warm up is worth the extra money that the micathermic would cost.
If your ceiling is well insulated (including over the wall plates at the top of the internal walls) then the large windows are very likely the reason that your underfloor heating can't get the heat high enough. Have you considered double glazing? 3M have a very cheap, disposable window insulation kit that you could put on for a cold season to see if it's worth putting in some more permanent double glazing (and in fact that kit will probably last 2 or 3 cold seasons if you just leave it up).
The heater power (kW) required to get that extra 2 degC depends on how well the room is insulated. Your best bet would be to find out how much kW your underfloor heating is putting out and how much degC it is warming up the room, then keep the same proportions to work out how much extra kW you need.
Jan 13, 2009 | Soleus HGW-203 Micathermic Infra-Red...
Hunter Mechanical Heat & Cool Thermostat 40135 Logo
207 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
