Question about Onkyo Audio Players & Recorders
Onkyo TX-NR727 - no sound
Receicer only one month old. Suddenly no sound at all
  • 7 Answers
SOURCE: Onkyo TX-DS797 - No sound
There is a technical bulletin from onkyo where in the problem is in the relay ckt
Posted on Nov 13, 2008
  • 13 Answers
SOURCE: how powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Posted on Mar 04, 2009
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
localwonder
  • 6784 Answers
SOURCE: Onkyo TX-SR605 - Suddenly switches itself off and back on
HI, this is a reset procedure that this unit is trying to initiate. there has been a surge of some sort that the system has survived but, there is some lasting damage as well that has resulted in a slight programming error within the mother board.
This unit has a program that was installed at the manufacture. it runs the basic operations. there has been some major damage that is causing the internal program to stall and reset itself. the only way to reprogram is to send it back to the manufacture or, you can locate a local repair depot through Onkyo. the Onkyo techs are the only option when re programing is needed.
Posted on May 13, 2009
  • 4 Answers
SOURCE: connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Posted on Jun 17, 2009
Onkyo TX-SV515PRO2 -- circa 1994 When I turn it on sometimes there is no sound. I turn up the volume (sometimes loud) until this triggers the sound to suddenly work. Speakers work great.
Hello, I am sorry about your issue. It sounds like the receiver needs to be serviced. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo Audio Players & Recorders
Loosing sound TX-NR727 watching TV
Hi George, does this happen on all of your sources? What type of connections are you using and what is the distance between the source and the receiver, please advise. Note that you can email me directly at askOnkyo@us.onkyo.com, thanks, JT
Sep 15, 2015 | Onkyo TX-NR727
Program direct tv remote rc65rx
Hi, if you are programming the Direct TV remote you will need to get the codes from Direct TV, Thanks, JT
Mar 05, 2015 | Onkyo TX-NR727
Onkyo tx-sr507. was listening to music and suddenly cut out. Will not restart despite disconnecting all speakers etc. standby light flashing
standby light flashing means that it has had a thermal meltdown given that the onkyo can not be that old i would contact onkyo support because our model should be under factory warranty
May 24, 2010 | Onkyo Tx-sr507 A/V Receiver
Onkyo TX-Sr603 goes back to standby when press On button - help!
does not sound like the fuse.
its easy to check. unplug unit and remove the cowling / shroud of the unit. the internal fuse will look like a car fuse. the old round style about 1" long and 1/4" round.
sounds like a bigger problem. hope this helps.
Feb 19, 2010 | Onkyo TX-SR603X Receiver
May 13, 2009 | Onkyo TX-SR605 Receiver
2 month old ONKYO TX-SR706 speaker circuit problem
This is a problem with the surround sound processing. Effectively the digital signal is not being processed properly. Since this unit is so new, return it and request either an exchange or at least warranty service. The DSP board will likely be replaced.
Dan
Feb 16, 2009 | Onkyo TX-SR605 Receiver
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
Sep 02, 2008 | Onkyo TX-DS797 Receiver
29 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
