Question about Indesit Washing Machines
Indesit idw 7145 noisy bearings - Indesit Washing Machines
3 Suggested Answers
  • 53 Answers
SOURCE: Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Posted on Mar 07, 2009
heatman101
  • 43501 Answers
SOURCE: noisy bearings on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Jun 08, 2010
If indeesit iwd 7145 write f 12 what is the problem
F12 indicates that the upper control board is not communicating with the main control board, check its wiring and its connections.
Identifying Hotpoint or Indesit Error Codes
Nov 27, 2015 | Washing Machines
I have an Indesit IWD 7145 S and it is not washing properly and flashing code H20
You posted in the photography forum not in the washing machine forum.
Apr 11, 2014 | Washing Machines
Washing machine very noisy when spinning
Probally the bearing seal failure causing water to seep into the bearings. You will need to replace the seal and bearings to fix. It is a big job since the washer needs to be taken apart to replace the bearings.
Sep 09, 2010 | Indesit Washing Machines
Indesit WIDL1265 - Noisy on Spin
Hello, this is a symptom of drum bearing wear, and what you need do is to check the wear to see if the inner drum moves up and down relative to the fixed outer drum. It should only moves a minutes amount. If it moves more than a millimeter or two, that means it is probably worn bearings and you will need to replace it.
Thanks
Jun 10, 2010 | Washing Machines
Noisy bearings on spin cycle
heatman101
Jun 07, 2010 | Indesit W 123 Front Load Washer
How do i change the bearings on my indesit we12s macine
Sorry but you can't.
Your model has a polypropylene outer drum and the bearings cannot be removed without breaking it. The only fix is to either replace the entire drum assembly or just the outer drum which is supplied with bearings ready-fitted. If you do go ahead with the repair it's a good idea to replace the drive belt at the same time unless it's absolutely perfect.
As Indesits are super-low priced machines to start with the repair is rarely economically worthwhile as a machine with worn bearings will usually have many other worn parts as well just waiting to fail. Noisy bearings make a horrible noise but usually continue working for quite a while, so it may be better to grit your teeth and put the likely repair costs into the savings towards a new machine.
Feb 15, 2010 | Washing Machines
Mar 07, 2009 | Indesit W 123 Front Load Washer
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Washing Machines Logo
46 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
