Question about Canon FAXPHONE L80 Laser
How do you get a fax from memory
It says load paper, but paper is loaded correctly because when unplugged and replugged it prints out sheet of faxes.
How does one fix reload paper without unpluggin g and losing the fax in memory.
Posted on May 20, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
My lexmardk z645 saying its printing...when it begins...it makes an annoying sound and says out of paper....
Try to empty the printer of sheets of paper. Open the cover where the cartridges and remove the cartridges. Check for any loose strips inside the printer or maybe pieces of paper that got torn. If none found, close the cover. Unplug the printer from the power source, replug after 30 seconds. When the printer's ready, reload the cartridges. Load some paper, don't overload. Try to print again. If problem continues, you may be having a hardware problem. I suggest you contact Lexmark technical support to further investigate the problem.
Aug 31, 2010 | Lexmark Z640 InkJet Printer
My lexmark all in one printer x5470 keeps jamming the paper and it wont print?or the paper will go in partially and print but nothing will happen then it will tell me to reload the paper and press the...
Most probably a mechanism problem. Try to remove all sheets of paper. Take out the cartridges from the printer. Close the cover. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Check for any obstructions or foreign objects in the feeder. Wait at least 30 seconds before plugging the power supply back in the printer. Once printer is ready, reload the cartridges. Load about 10-15 sheets, don't load too much. Let it print the alignment page. If this doesn't help, then most probably it's a hardware issue. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem.
Jun 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
My pixma mp 150 shows me E 2
Error E2.
Action : Reload the paper correctly and press [Black] or [Color].
Loading Paper
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
- Set the Paper Thickness Lever to the correct position for the paper.
Important : Make sure the stack does not exceed the Load Limit Mark.
Hope this helps.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
To fax more than 1 sheet of paper, print side up or down?
One sheet or multiple sheets the procedure is the same and laid out in this MANUAL
Apr 22, 2009 | HP Officejet 5610 All-In-One InkJet...
My brand new X5340 printer shows there is a paper jam but there isn't one. The one and only sheet it has printed was the test page. Since then, I have been unable to get rid of the "clear paper jam"...
hi
follow these steps
1.checked for and remove any obstructionsfrom paper feed tray.
2.tilt and shake printer..checked for any rattling noise..checked for any foreign objects inside printer obstructing the paper flow.
3.Take a sheet of paper ..fold it length wise 3-4 times to make it a thick.insert this into paper feed tray...move it left and right a couple of times..unplug power cable and replug it after 10 seconds...try printing ...if it does not work,,,,contact tech support 1-800-332-4120...ur printer is brand new and under warranty cover,,,they would replace it for u.
goodluck:))))
Jan 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
Paper won't load
first this to do is turn it off unplug, take paper tray out and remove paper and clean the tray, take the printer and put it on it's side (the side where the paper tray goes and see if you get any paper dust to come out. other wise blow air into that area you will see a roller on top need to clean that.
Feb 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon FAXPHONE L80 Laser Logo
252 people viewed this question
old marine
old marine
