Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Mower ran great two weeks ago. I went to start it yesterday, and didn't hear any type of noise when I turned key. Battery shows fully charged. Any suggestions?
  • tonync1221 May 19, 2009
    The fuse is good. Only safety switch I know is the dead man switch under the seat. I cross jumped that and still get nothing nut the click and the ampmeter goes down a little.
    Sniper:
  • 57 Answers
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
Posted on May 19, 2009
Key will not work on ignition.
it has and oil safty switch on it you will have to push it to some flat ground to start it you will have to wait to start it let the oil settle down to level dont leave lawn mower on a hill it will happen every time
Aug 16, 2014 | M T D Products Mtd Gold 50"" 25 Hp Zero...
Murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Jun 16, 2012 | Garden
Lawn Boy 10641
see if the oil smells like gas the carb maybe sticking and gas gets into the oil washing the oil out this will make hard starting and smoke if so the needle valve is not sealing if you caught in time without major engine damage a sign is the oil being over full and smelling like gas
Apr 03, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
My Murray 20" 3.5 hp classic throttle free design
it possible snap its main rod if it freely spins no compression buy new motor
Jun 08, 2011 | Briggs & Stratton Garden
Mower ran fine a couple days ago. Went to start
Remove the plug, pull the rope several times. Wait about 30 minutes. Put the plug back in. Try again.
Choke off? Use sparingly if at all. If you have a primer button, only press it 5 or 6 times.
Is your plug in good contition? It may need a replacement. Make sure you get the correct plug.
Let me know how this works out.
a
Sep 21, 2009 | Garden
My 18hp murray riding mower ran good a couple of weeks ago. Now it started up and ran only a few seconds and quit. The key turns over the engine but will not fire anymore. What could be wrong with it? John...
Some of the machines need to be adjusted for the head gabs check the gabs and see if they need to be adjusted. Let me know
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | Briggs Stratton 20-Amp Power Transfer...
Murray lawnmower
you may just need to remove the nut that holds the float bowl, and inspect the nut itself, half way up the nut should be a little tiny hole in the side.
use a bread tie stripped of the plastic covering and unclog this little hole, then replace the nut , when that hole becomes plugged the main jet cannot get fuel for the venturi pipe, thus the mower will start and hit a couple times then die immediately, that may fix the problem
Sep 15, 2008 | Garden
Murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Sep 06, 2008 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
567 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
