Question about ESI Led Under Cabinet Lighting single Unit-LEDUC
Replacement lighting tubs - ESI Led Under Cabinet Lighting single Unit-LEDUC
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Tip
How to service tub & agitator
The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
on Jan 16, 2010 | Washing Machines
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jacuzzi tub not heating
O ring set may be required slow job take care
Sep 18, 2009 | Home
It knocks on spin cycle
The tub may be off balance.
Servicing the Tub and Agitator
©2006 Publications International, Ltd.
Unscrew the cap on top of the
agitator and pull straight up;
the agitator should lift off.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
Sep 10, 2009 | Washing Machines
Washer drum bangs from front to back
This may be a drum or agitator problem. Possibly bad bearings or coupler
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
How to replace tub seal on Maytag sav4655eww
you need a 1/4" nut driver and a spanner wrench-start by taking 1/4" screw located toward lower part of agitator,its recessed,take it out,then lift out agitator, then mark where your drum is so you get replaced in that location(counter-weights)then take spanner wrench and loosen nut that holds the wash tub and lift out tub,turn tub over and w/rubber mallet driveout old seal,to aid in new seal install lightly lube with vegetable oil(wessonoil-pam cooking spray) and tap seal into place and re-install in reverse order
Jul 26, 2009 | Maytag Washing Machines
Cracked housing to underwater tub light
I belive but am not positive that those lamp assemblies are required to be low voltage. In other words, there is no safety issue if water contacts the builb or wiring. Call Americh to verify. The lens ought to be easily replaceable so as allow for bulb replacement. Ask Americh.
Jul 11, 2009 | Home
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Clothes
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
check out for this link
http://www.applianceaid.com/frigidaire_frontload_washer.html#noise
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ESI Led Under Cabinet Lighting single Unit-LEDUC Logo
66 people viewed this question
Top ESI Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an ESI Health and Beauty Expert? Answer questions, earn points and help others
