SOURCE: Marantz CD-5000 CD player
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
SOURCE: CD NOT WORKING
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
SOURCE: Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
SOURCE: Pioneer automotive stereo cd player error 11
I have the same problem now too. It shows up error 11, 12 or 17. I tried using a cleaning CD but did not work. I think the lens needs to be replaced.
SOURCE: HU 850 CD stuck in player
One thing about Volvo CD player/changers...they tend to not like burned CDs and even more, burned CDs with labels on them.
I'd suggest against trying to get it out yourself.
You can get it replaced and the dealership should have a form so you can get your CDs sent back.
