SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
SOURCE: 52LG70 sometimes turns off and on periodically
I had the same problem. I changed the 4-3 setting on the motorola cable box. Turn off your cable box and press menu. My 4-3 setting was set to auto. If you turn it off, you lose the 4-3 aspect on most channels. I changed mine to 480p and so far it seems to be working. Worth a shot.
