Question about Activision Call of Duty: Finest Hour
Sound prince warrior
Tecsetup.exe incompatible with my systeme of 64bit (win7)
Prince of persia two throns not working my pc just show unknown amd proccessor? what should i do to play this game ?
hai, you have to do:
first run the program "princeofpersia.exe" from installed folder. this will detect the supported hardware and o.s.
second: don't quit the program after detecting.
third: run the program pop3.exe from your installed folder. it will magically run the game .
Don't quit the first program........................enjoy..THANKS
Feb 08, 2013 | Ubi Soft Entertainment Prince of Persia:...
HOW TO USE TRAINER IN PRINCE OF PERSIA WORRIER WITHIN
First play the trainer of prince of persia then play game.Press hot keys of trainer.Then work your trainer.
  • eg of hot keys is F2 F3 F4 F5
Mar 22, 2012 | Ubi Soft Prince of Persia: Warrior Within...
I downloaded prince of persia warrior within and want to play it, but when i clicked on princeofpersia warrior within.exe, it showed that it is not a valid win32 application.
Make sure ur using windows xp
and hardware minimum requirement
then also same problam it mean ur exe is currrept try to replace ur exe file
Sep 22, 2011 | Ubi Soft Prince of Persia: Warrior Within...
Princes of persia Warrior within if you can help me to change the settings on Prince of persia warrior within to windows 7 i can't play in windows 7 can you hellp me Plizz ^_^
Have you tried changing the properties of the shortcut to run in WinXP SP2 compatibility mode?
Right click the shortcut, goto properties/compatibility tab, choose "WinXP SP2 compatibility mode" in the dropdown box, then click apply.
This should solve your problem. If not, come back with a bit more detail, and it can go forward from there.
Hope that helps.
Cheers from NZ
May 09, 2011 | Ubi Soft Prince of Persia: Warrior Within...
I NEVER HEAR ANY MUSIC OR VOICES IN THE CUTSCENES IN PRINCE OF PERSIA WARRIOR WITHIN BUT I CAN ONLY HEAR SOUND EFFECTS
HAI vishal its because the game you have is a rip game.It means they will delete the sounds inorder to get the size reduce .if u wanna fresh one you can download it from www.torrentz.in
Apr 18, 2011 | Ubi Soft Entertainment Prince of Persia:...
Cannot install Selphy CP400 onto a Windows 7 (64 bit)machine.
download vista 64bit drivers (cp400x64mux.exe). Extract these using winzip or winrar or 7zip. Rightclick CNYCPINS.EXE, click Properties, click Compatibility tab, and select Vista SP2 mode. Connect printer, rightclick CNYCPINS.EXE and click 'run as administrator'. Printer is now installed, works fine on my Win7 Home Premium 64bit.
Nov 02, 2010 | Canon Selphy CP400 Thermal Photo Printer
Prince of Persia - The Two Thrones - Doesn't Start I am running:- Core2Duo, Windows XP, SP2, NVidia Gforce 7600GT, Dual Monitor, dxdiag 9.0c When I run pop, it says checking disk, then goes to direct draw...
make sure u run demon tools before running the game,,,
ang also update the starforce protection software to make the game work in any os...
the link is
http://www.star-force.com/support/drivers
Apr 26, 2009 | Ubi Soft Entertainment Prince of Persia:...
Activision Call of Duty: Finest Hour Logo
37 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
