Question about Samsung SyncMaster 172N 17" LCD Monitor
Color screen my screen is green. how to solve this problem
  • 55 Answers
Check with a different VGA cable.if does not work then to get in touch with a hardware technician
Posted on Dec 30, 2013
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Hello, My name is Diane. I've had my flat screen Acer monitor for 14 months and all of a sudden my monitor has no red, orange or pink color. My screen colors are green, blue and yellow. What is the...
hello Diane, actually yellow is mixed red and green.
I thing you should check your cbf cable first (VGA cable).
Or if you have pattern test, use it to make sure which color has lost.
Change VGA cable may can solve it.
If any problem, please let me know.
Thanks and good luck.
Mar 27, 2011 | Computers & Internet
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Color Display problem
it seems that problem that ur facing is manly related to drivers but try booting into safe mode and incase ur screen look normal in it try installing the driver from support.dell.com.or check in bios and check the screen in case ur screen is still bad then contact dell
Feb 03, 2009 | Dell Inspiron 1501 Notebook
My T.V. has a funny color .. more of double viewing with purple and green what can I do to fix this?
Degaussing means to demagnify. Not applicable with a projection tv. You have a severe convergence problem. Either a component failure, a speaker or other powerful magnet in very close proximity or someone figured out how to adjust (or misadjust) it.
Dec 31, 2007 | Televison & Video
Green Screen
check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
Sep 12, 2007 | Insignia IS 20" TV040919 TV
Samsung SyncMaster 172N 17" LCD Monitor Logo
47 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
