Question about Beko Dishwashers
Dishwasher fault finding
After being washed glasses and dishes feel gritty
    New Friend:
    Problem Solver:
  • 8 Answers
You water level in your dishwasher is probably low if you change your water valve and run a dishwasher cleaner through it that will solve your issue
Posted on Jan 15, 2014
4 Suggested Answers
  • 109 Answers
SOURCE: A gritty feel is left on glasses and some dishes
Hard water! Try Cascade Rinse Aid.
Posted on Mar 25, 2009
wheelshot
  • 102 Answers
SOURCE: Dishwasher
Make sure not to prewash your dishes before you put them in the machine. The water needs to be dirty to activate the enzymes in the detergent. Are the dishes coming out cloudy? Also a sign of prewashing your dishes. Use only powder detergent and clean your machine by running 2 cups of vinegar on hottest cycle once a month. No gel and no tabs. They cause a build up in the unit and causes poor performance. Use rinse aid. Hope this helps.
Posted on Apr 11, 2009
woodchuck789
  • 4070 Answers
SOURCE: My dishwasher is leaving gritty, sandy particles
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Posted on Jul 12, 2010
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
What would cause dishes to feel gritty after being washed?
Make sure water level is touching heater and is above 125 deg F
Dec 03, 2010 | Frigidaire FGHD2433K 24 in Builtin...
Residue left in glasses and a film on the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jun 09, 2010 | Maytag 24 in. MDBH940AW Built-in...
Grit on the dishes. Foggy glasses. Blue type stain on the stainless flatware and the stainless inside of the dishwasher is very cloudy and streaked. Many areas inside the dishwasher feel gritty.
May 03, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Mar 25, 2009 | Dishwashers
Dishes have soap residue despite using rinse aid. Machine is quite abrasive on coffee mugs etc. Unit is Fisher & Paykel DD605SS
use less soap.....excess soap in the rinse cycle will not allow the dishes to rinse properly causing white etching on the glasses and the dishes will have that gritty feeling
Aug 02, 2008 | Dishwashers
Dirty dishes
Try putting a cup of white vinegar in the empty dishwasher & running it on fast wash. Should eliminate film; do you have hard water where you live? If so lime build up could be the problem.
Hope this helps.Cheers.
May 16, 2008 | Dishwashers
Dishwashers Logo
155 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
