Question about SeaSonic PSU SEASONIC|SS-650HT 650W RT (S12 Energy Plus 650W) 650-Watt Power Supply
Stable bhatt I am unable to find SeaSonic PSU SEASONIC|SS-650HT 650-Watt Power Supply
GM5664 shuting down
You can check temps in your BIOS. That'll tell you if it's an overheating issue.
If temps are normal, suspect a problem PSU or even other hardware. My first guess would be overheating though.
You can check for shorts on the board or bad capacitors. But these are pretty classic symptoms of an electrical or overheating problem. Your temperatures aren't indicating overheating, so there's something funky with the electrical/power system.
The fact that it shuts down with a higher performance mode to me would indicate faulty power.
It sort of seems to me that either you have two bad PSUs (unlikely but entirely possible) or you have a motherboard problem. Replacing a power supply is both cheaper and easier than replacing a motherboard. Now, if you get a third PSU and you're still having the same problems it might be time to look at the motherboard and it's components.
and also Swap the power supply for something like this one:
Newegg.com - SeaSonic S12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
/or/
Newegg.com - CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Apr 18, 2014 | Gateway GM5664 Desktop PC
Hello, I recently bought a CX500 PSU, and i have an issue with it. When I unplug the wall power cord and then plug it back, the PC turns on by itself and all my BIOS settings are reset with a MemOK!...
Did you check the battery on the motherboard? The battery should read 3.3 volts with a volt meter. If you don't have a meter you can try swapping the battery from another motherboard. Or have the battery checked at a Radio Shack store. Also if you still have the Seasonic try hooking it back uo temporally outside the case to check if it is a power supply issue. If the old power supply failed while being connected to this motherboard it could have damaged it.
Thanks for using FixYa
Jul 02, 2011 | CORSAIR Builder CX500 (CMPSU500CX)...
Need schematic for seasonic model P4-360W computer power supply. Transistors are blown and can not trace their particulars. It is 350W paower supply
Repair on a scale as you have described is normally not practical. Replacement Power Supply is more cost effective. See ebay for details.
Feb 07, 2011 | Computers & Internet
WHICH POWER IS COMPATIBLE WITH THE CACT05UW CASE
ANY good power supply will fit.
Go for a good make 80+ rated supply
Try
seasonic
silverstone
ocz
enermax
Or just google 80+ psu
Aug 19, 2010 | Computers & Internet
FUSE BLOW UP
Replaced 400MF/350V capacitor (was shorted) and the 8Amp fuse.
Feb 27, 2009 | SeaSonic Computers & Internet
SeaSonic PSU SEASONIC|SS-650HT 650W RT (S12 Energy Plus 650W) 650-Watt Power Supply Logo
18 people viewed this question
Top SeaSonic Computers & Internet Experts
David Payne
David Payne
Are you a SeaSonic Computer and Internet Expert? Answer questions, earn points and help others
