HP 2000 POWER BTN FLSAHES DARK SCREEN
FLSAHES DARK SCREEN
    Top Expert:
  • Computers & ... Master
  • 25,737 Answers
Try removing the power supply, battery, hard drive and RAM. Plug in the power supply and press power. If the screen recovers, add the RAM followed by hard drive. If it stops working at any point, that is the issue. If it still doesn't work, I suspect a GPU issue. (Possible overheating). If it now works, maybe a bad connection.
Posted on Dec 30, 2013
How to print my puzzle from The daily commuter puzzle by Jaqueline Matthews
press the print screen btn then open MS Paint ,past and save as *.jpeg now print it.
May 26, 2015 | HP Office Equipment & Supplies
Am confused,i want to buy a colour laserjet printer and left with only two options which one should i buy btn hp1600 and cp1525
hiii
Its depends on your printing needs.Printing quality almost same these two printers. If u buy hp 1600 u will get more pages than cp 1525.But u should think about the toner cost. Check your local market price for each toners.Here i will give u the toner model numbers for ur required printers.
hp 1600 - q6000- black,q6001,q6002,q6003 each three colours.- Page yield 2500 pages for black ,2000 pages each colours.
hp cp1525- ce-320a(128a),ce321,ce322,ce323- Page yield -2000 pages for black,1300 each colour pages.
So I am sure hp 1600 toner very costly than 1525 toner.If u dont have huge volume printing better i suggest u buy cp 1525 model.Also this model offering wirless printing .
U can refill this toners lowest cost and getting good results.
sooooooo cheeeeeeers up........select your new printer. best wishes..........
Jun 14, 2011 | HP Color LaserJet 2600n Printer
Trouble codes 604 and 1604
SEPHIA(FB) >2000 > G 1.8 DOHC > Engine > Engine Control > P0604 Internal Control Module Random Access Memory (RAM) Error .YOU HAVE AN OPEN SOMEWHERE CHECK THE BTN FUES UNDER THE HOOD AND CHECK THE ECM FUSE IF THEY ARE OK . CHECK ECM CONNECTOR THE ECM IS LOCATED IN THE CENTER OF THE FLOOR UP UNDER THE DASH BOLTED DOWN WITH 3 10MM BOLTS NXT TO THE ACCELERATOR PEDAL CHECK CONNECTOR FOR CORROSION IF EXISTS CLEAN AND RECONNECT AND RECHECK. IF IT NO CORROSION YOU HAVE A OPEN FROM BTN TO THE ECM
Jan 18, 2011 | 2000 Kia Sephia
What does BTN2 40amp fuse mean?
I only know what it does, BTN 2 as being a 40 amp fuse for the - JB radio , CD changer , cluster , dome lamps , map lamps , cargo lamps , horn relay , GEM , power locks , speed control - but what BTN 2 stands for , I don't know, Ford company will be able to tell you the meaning.
Sep 21, 2009 | 2002 Ford Escape
The printer will not turn on.
Printer needs service or it's a problem of printer logic card.
check it to nearest service centere .
Good Luck.
Dec 08, 2008 | Epson Stylus Photo R300 InkJet Printer
Hp pavilion dv4000 screen is dark and unreadable
hi this is a website where you can dawnload service repair manual
http://www.laptop-repair.info/hp_laptop_repair_manual.html
check with it
regards
Sep 18, 2008 | HP Pavilion dv4000 Notebook
Dim screen ph nx9110
good morning sir,,
now u have to find a button in ur keybord which has symbol of sun and a + beside it. do press the specified button to access the button(function btn,shift btn) nad te brightness button,
another method is :
right click in desktop- goto properties - clik setting - adjust the gamma settings
fixed by fixya
Jul 08, 2008 | HP Computers & Internet
Aoc 5en no display
I alreeady encountered this problem. I fix it temporarily.... I just turn it off, Press all the Function btn and the recall btn, then pres the On btn... wait for 2 sec then release the func, recall btn. Then I already able to use the PC for about o hours without interrupted signal (on/off). I call it temporary fix because whenever you turn off the Monitor, you have to do the same process again..
Try it it can help.. Thnaks.... If you already find solution , maybe you can share it to me too .. Thanks..
Jun 25, 2008 | AOC 5 En 15" CRT Monitor
Screen problem Hp dv1000
The main two causes for this, are the inverter, which supplies the screen with the proper amount of power in order to function correctly, or the screen. If the inverter isn't puting out enough power it will cause the screen to darken or black out completely. Start by checking the screen connections. If all the connection are properly seated, the it's either the inverter or the screen it self.
Jun 20, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
