Question about Brodit ProClip for Ford Ka 2009 - 2013 Angled mount
Warning light lit ford ka
The light is orange and shows a steering wheel
A warning light is coming on my ford ka dashboard that looks like a steering wheel what does this mean
what year is your ka? if its the later model it has electric power steering. the warning light means a fault in the system or it needs to be recalibrated ie. if the battery has been disconneted or gone flat. try with engine running turn steering wheel from full lock to full lock both ways a couple of times if that dont work there is poss a fault in the system and needs to go to a dealer for safety reasons good luck
Jan 29, 2017 | Ford Cars & Trucks
What do I have to do to replace air bag/horn switch on a 2005 Ford F350 6.0L diesel?
Horn swith or clock spring ? Is air bag light lit on the instrument cluster ? You would have to take air bag module off the steering wheel .An to do that you have to deenergize the air bags , pull a fuse an disconnect the negative battery cable . Then you have to pull the steering wheel . Videos on youtube showing to replace clock spring ! Steering Column Airbag Clockspring Repair Ford Superduty 1999 Up
Nov 11, 2016 | Ford F-350 Cars & Trucks
At idle Engine accelerates when moving the steering wheel
That could be a tough one to diagnose ! I would start by pulling the steering wheel off an check wiring inside , see if lose connection or wire chaffed an touching metal ! Does it have buttons on the steering wheel , cruise control ? or on the stalk on the side of the column ? Is air bag light lit on the dash ? Short in the clock spring , Do you know what a clock spring is ? Ford Windstar Steering Wheel Clock Spring Replacement B1932
Sep 16, 2016 | 1999 Ford Windstar
Horn not working i believe it is a fault on the steering wheel. Can i safely remove the airbag to get to the horn?
Pull the air bag fuse or disconnect the negative battery cable an wait a few minutes , then you can remove the air bag safely . What country are you from ? Do you have an air bag light lit on the dash as well ? Possible clock spring problem , it's located inside the steering column under the steering wheel . This clock spring allows the steering wheel to turn from right to left keeping the air bag , horn , speed control ( if you have the buttons on the steering wheel ) . Connected electrically . There is also a relay located in a fuse / relay box . Do you know what a relay is ? VEHICLE RELAYS Operation Diagnosis
Aug 19, 2015 | 2005 Ford Ka 1.3
What does the steering wheel indicator mean when lit up on dashboard? Just changed the oil and now the check engine light and the steering wheel light are on.
Steering wheel indicator light means electronic power steering inoperable.
I think I would try to disconnect the battery for about two- three minutes and reboot the computer. This might be handy.
http://cdn.polarisindustries.com/polaris/common/parts-manuals/9924160r01_lo_res.pdf
Dec 29, 2014 | Polaris 2013 Ranger XP 900 EPS Orange...
My ford ka 2005 has electrical fault. Right indicator works sometimes, interior dashboard lights not at all and hand brake light on permanently
I have a ford ka 2006 and there is an intermittant fault with the dashboard lights coming on / off i have undone the steering wheel cowl and checked the plug onto the indicator stalk and this did not fix it also checked and played with indicator / light stalk still no good just comes on / off at any time any ideas?
Sep 22, 2009 | Ford Focus Cars & Trucks
Steering wheel off centre on ford ka, had tracking
if wheel is offline then the person who done the tracking is responsable and take the car back to them and get them to put it right .the correct way is to adjust each track rod end a little bit not all the adjustment on one track end ,which throws out the wheel alignment .this means that you lose steering lock on one side .THIS IS COWBOY BODGE JOB .If they cant or wont put it right then take it to someone who can and report them to the office of fair trading and make a legal claim for the job to be put right
Sep 01, 2009 | 2000 Ford Focus
Hazard warning lights and horn on a 2006 Ford KA don't work
Hazard warning lights and horn on a 2006 Ford KA don't work but indicators do
Aug 20, 2009 | 2003 Ford Escort
Warning light on dash
that would be the "Speed sensitive power steering" warning light.
need to have your power steering checked. First thing to do before taking your car somewhere is to check your power steering fluid level.
May 02, 2009 | 2005 Suzuki Swift
Steering warning light on 2005 suzuki reno
Speed Sensitive Power Steering
(SSPS) Warning Light
If your vehicle has Speed Sensitive Power
Steering (SSPS), this warning light will
come on briefly when you turn the ignition
to ON as a check to show you the bulb is
working.
Then it should go out after a few seconds.
If the warning light does not come on, have
it fixed so it will be able to warn you if there
is a problem.
If the warning light stays on, or comes on
while you are driving, the SSPS system
may not be working. If this happens, see
your SUZUKI dealer for service.
Feb 16, 2009 | 2005 Suzuki Reno
Brodit ProClip for Ford Ka 2009 - 2013 Angled mount Logo
69 people viewed this question
Top Brodit Computers & Internet Experts
David Payne
David Payne
Are you a Brodit Computer and Internet Expert? Answer questions, earn points and help others
