Question about Teac Audio Players & Recorders
TEAC A-L700P link cable
I have obtained a TEAC A-L700P amp and need to know the specification / availability of the LINK CABLE to DR-L700 receiver
SOURCE: multiregion for teac DR-L700?
Did you see this? http://www.avforums.com/forums/archive/index.php/t-149200.html
dom
Posted on Feb 04, 2008
SOURCE: g link cable
what do u need g link for???
Posted on Aug 16, 2008
SOURCE: cannot configure d-link 524 router to cable modem
You probably have to "clone" your computer's MAC address to the router. Usually the cable providers register your computer's physical address (aka hardware or MAC address). So in order to let your router get connected your router has to send the same MAC address. This is called MAC address cloning.
To get your machine's MAC you go run->cmd and on the command line write "ipconfig /all". This will show you the info of all adapters you have on your computer. Search for the ethernet adapter and get its physical address. It should look like (xx-xx-xx-xx-xx-xx-xx-xx) where x is a number 0-9 or a letter A-F.
Once you have that you need to go to your router's configuration page and find where you can insert the clone MAC. You may also need to enable the cloning from the same page.
Hope that will help.
Posted on Jan 18, 2009
  • 22 Answers
SOURCE: Teac Code for a cox universal remote to control a AG-D9260 AMP/Receiver
Try code: 2130
Posted on Mar 31, 2009
nandini789
  • 430 Answers
SOURCE: a network cable is unplugged
This message " A network connection is unplugged" comes when the connection unavailable may be due to faulty connection. Chek that your router is rightly plugged and the sockets are dust-free. If problem persists, contact support.
Posted on Aug 15, 2009
Testimonial: "Thanks, for the info. I had to call the router people and it is now fixed."
Looking for a TEAC UR-417 Remote control
go e-bay and in the want to buy search type in remote control for teac ur -417 enter and see what is available
contact teac direct on their web site and see if one is still available
remember that manufacturers seldom change the frequencies that remotes work on so even though the specifics may be a bit different , it probably would still work
Sep 25, 2015 | Teac Audio Players & Recorders
Flashing Power Light
your surround sound system seem like having dry solder joint at PCB . one thing you can do is to open up the back cover first looks for dry solder joint ( if you can find ).if not just re-solder those solder looks very thin.it may help.
Aug 02, 2007 | Teac Legacy DR-L700 DVD Player
Teac DVD L700 Power Supply
The only thing I can tell you is to check the cable if its plugged in correctly... wierd! might be electricity problem to where you moved it. Did you hit it while you were moving it?
Pre out connection/cable,. how to
Just put the amp jack in the RED socket if is marked or Right socket. It will not effect it, having the other one not used. But you can get a stereo to mono jack lead if you want.
Mar 22, 2013 | Teac AG-V8060 Receiver
NEED REMOTE CONTROL CODE
Here are a couple of codes that might work for your TEAC receiver.
0163, 0463.
http://www.hifi-remote.com/ofa/codes-amp.shtml#amp
Here is a link to a site that has Remote Codes.
Hope this helps,
Best Regards,
Mark
Jan 26, 2011 | Teac AG-D9260 Receiver
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
I lost one of the cables and the Cd-Rom that came with my HP PSC 2210 All-In-One Printer, Where can i buy replacements?
What cable do you not have? Tha power cord or the USB cable? A USB cable can be purchased at any office supply store...Staples, Office Max, etc. If it is the power cord you need you amy have to do a search on Google to find the correct one. One such site is PSC Power Cords
The software can be obtained at HP support. Here is a link:
PSC 2210 Support
Select Software & Driver Downloads. Then select your operating system. A list of available software will appear. Many will have a link to order a CD if you desire one, but you can download the software for free.
Thanks for using Fixya.
Sep 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
My teac ref500 amp switches its self now and then and will not switch back on for 5-20mins, can you help
This is a good indication that the amp is geneating too much heat. There are protection circuits inside that will shutdown the amp if it gets too hot. You will need to determine what is causing the excessive load on the amp to make it generate that heat. Look for crossed wires or problems in the speakers. This amp is designed for 4 ohms (I think) and a load less than that will still work, but cause the amp to work harder and generate excessive heat.
Please keep us posted.
Dan
Sep 04, 2009 | Teac Reference DR-H300
69 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
