Question about Dell Computers & Internet
Eeprom reset j1knd
Need to reset the battery eeprom / counter
How can I reset the counter on a Samsung clp-415n
Laser printer counters are stored in the EEPROM on the printer. The only way to reset the counter is to change the EEPROM, usually by changing the logic board. The only reason I can see for resetting the counter is the same as clocking a car (to change the number of miles travelled displayed) in order to command a higher price on resale.
Jan 19, 2015 | Samsung CLP-415N Network Colour Laser...
Keep getting error code 5200, turn off and turn on again
Hello, you need to reset the waste ink counter:
  1. Start with the printer OFF
  2. Hold down RESUME and then hold down POWER
  3. release RESUME
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Number of presses Light color Function 0 presses green Test print (or exit service mode on i960) 1 press orange EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses green EEPROM initialize 3 presses orange Reset waste ink counter
Jul 28, 2014 | Canon i850 InkJet Photo Printer
Printer displaying E 2 2
Hi hatti
The E22 is the error is displayed in Canon printers. And it relates to waste ink pad full. follow the correct instructions for perfect results.
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
Take care.
Aug 23, 2011 | Office Equipment & Supplies
Canon IP 1980 resetting
- The service mode functions are same as those of the previous models.
1) Test pattern 1: Service test print pattern 1 will be printed.
2) Test pattern 2: Service test print pattern 2 will be printed.
3) Test pattern 3: Service test print pattern 3 will be printed.
4) Cleaning at the service test print: Check the Cleaning box and perform the service test print.
Cleaning will be performed before the service test print is printed.
5) EEPROM initialization at the service test print: Check the EEPROM Clear box and perform the
service test print. EEPROM will be initialized.
6) Destination setting: Select the device ID to set the destination.
7) Ink absorber counter resetting (Main): Main ink absorber counter will be cleared.
8) Ink absorber counter resetting (Platen): Platen ink absorber counter will be cleared.
9) Device ID acquisition: Device ID will be displayed on the PC.
10) EEPROM information acquisition (Dump): EEPROM information will be displayed on the PC with
the HEX dump.
11) EEPROM information acquisition: EEPROM information will be displayed on the PC.
12) Nozzle check pattern print: Nozzle check patter will be printed.
13) Cleaning A: Cleaning A will be performed.
14) Cleaning B: Cleaning B will be performed.
15) Cleaning C: Cleaning C will be performed.
16) Cleaning D: Cleaning D will be performed.
Aug 22, 2011 | Canon Office Equipment & Supplies
Error 27
Hello.
Here's what you need to do;
Make sure the printer is powered off but connected to a power source, then press the Power button while pressing and holding the Stop/ Reset button. And turn on, press the Stop/Reset button two times while pressing and holding the Power button. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Jun 17, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The ink absorber is full
1.With the printer powered off but connected to a power source,
2.When the Power is lit, press the Stop/Reset button two times
3.When releasing the Power button and the Stop / Reset button (regardless of order),
4.When the on/off lights in green, press the Stop/Reset button the
and green, starting with orange.)note: press 4 times for waste ink counter reset. The number of the Reset button pressing LED Function Remarks
5.Turn off the printer.( it must be turn off) then turn it on again.
Dec 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP160 All in one deskjet printer Error code E 2
E2 is waste ink counter.
Try holding Sto/Reset button for ten seconds.
If that does not work, try procedures below:
* With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
* When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
* When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
* When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
* Turn off the printer.( it must be turn off) then turn it on again.
from Fixyourownprinter
Oct 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber
You don't need to replace it. This is how to reset the Ink Aborber error:
How to clear E27 Waste ink absorber full
Jan 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to reset wasted ink counter
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Nov 22, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Computers & Internet Logo
180 people viewed this question
Alun Cox
