Question about ASUS Z9200 Laptop AC Power Adapter (4.3A 75Watts) by Amstron (Generic) AC Adapter
Asus z9200 CMOS battery replacement
How to replace CMOS battery
SOURCE: disassembling ASUS Degatto Laptop
Thanks Steel Breeze!! I did exact as you suggested and it was easy. I used a Dremmal tool to cut a squre holes. You can actaully see part of the battery (CR2032) through one of the existing holes.
Posted on Jul 14, 2007
  • 87 Answers
SOURCE: CMOS Checksum Bad
bios update might fix the problem http://support.asus.com/download/download.aspx?SLanguage=en-us
if da above link doesnt work check dis alternate link but i am sure it'll work
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Asus/Asus-P4P800-SE-Afudos-BIOS-update-tool-226.shtml
Posted on Nov 18, 2007
  • 109 Answers
SOURCE: How do I replace the cmos battery in a ASUS Eee PC
i think the cmos battery is under the keyboard. if it is there should be two screws under the laptop that will have the simbol of a keyboard, remove these and take out the keyboard. hope this helps
Posted on Jul 20, 2010
joecoolvette
  • 5660 Answers
SOURCE: How do I access the
If memory serves the CMOS battery for the EEe PC 1005HA is under the Palm Rest in the front.
You have to remove several screws from the bottom side of the laptop, remove the Keyboard, Static shield, then the Palm Rest.
The CMOS battery is the usual watch type of battery, but has two wire soldered to it. (Black and Red), and is placed in a blue plastic 'bag'.
At the other end of the wires is a small white male plastic connector.
This connector plugs into the motherboard.
This shows a generic 'knock-off',
http://cgi.ebay.com/ASUS-EEE-PC-1101HA-1005HA-CMOS-Battery-ML1220-2E2E0X-/170580385354
NOTE*
$19.99
THAT is utterly ridiculous.
The battery is just a small watch style type of battery, with two wires soldered to it, that end in a connector.
The battery probably costs $2.
I suggest you take the battery out. See what the part number is on it, (CR2032?), and buy a new battery.
Go to a qualified computer repair shop, or car electronic stereo shop, and have them solder the wires from the old CMOS battery to the new one.
You may not want to try the soldering procedure, because it's a lithium battery. Excessive heat will make it go off like a bomb.
Here is the disassembly procedure to access the CMOS battery. This video is posted for accessing a wireless card module, (Also Harddrive),
http://www.youtube.com/watch?v=yehHh0GmnU0
Posted on Dec 19, 2010
paul2010
  • 160 Answers
SOURCE: I replaced the cmos battery
remove the cmos battery and with a piece of conductive wire shrt negative and positive terminals for around 5 seconds then replace the cmos battery, ensure power lead is disconected, this may help
cheers
paul
Posted on Dec 22, 2010
How can you change cmos battery in asus f3jc laptop
I think it is under the RAM. Here is a link in case it is on the other side of the motherboard.
Asus F3S Asus F3S disassembly How to replace HDD RAM
Oct 10, 2016 | ASUS Computers & Internet
ASUS ALL IN ONE computer ET2221i-b85 The time is not correct and keeps losing time. I want to replace the cmos battery .
Keeping time has always been a problem for computers, as their internal clocks needed something to synchronize with. If you have an Internet connection and use Windows, you can get the time adjusted regularly using a time set function from Windows online. The CMOS battery will have little to do with time settings, unless it goes bad. Then, not only will your date and time go out of sync, so can many other settings in the CMOS. So, unless you are getting a low battery warning, or both the date and time are out of sync, you probably don't need a new CMOS battery and replacement probably won't fix you time drift issue.
In Windows 10, to get auto time sync, go to "Settings", then select "Date and Time". Under this you will see an option to "Set Time Automatically", as well as to select your time zone.
Aug 19, 2016 | ASUS Computers & Internet
How can I replace the CMOS battery an ASUS laptop?
There is no replaceable CMOS battery on this model.
It is probably a rechargeable battery on the motherboard.
See Manual which only mentions the main battery pack.
http://dlcdnet.asus.com/pub/ASUS/nb/UL50A/T4786_UL50.zip
Mar 15, 2015 | ASUS UL50Vt Notebook
Replace cmos battery and case openning
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
Dec 12, 2013 | ASUS CS5111-AP007
ASUS P5GZ-MX: Cmos Settings Wrong - Tryed New Cmos battery and setting time a date howto fix ?
It may just be that the new battery needs to be charged. I would leave it switched on for 24 hours to check. If this doesn't fix the problem, it could also be a failing BIOS chip or the charging circuit for the CMOS battery has failed. If the BIOS chip is not socketed or the cmos charging circuit has failed, you will need to replace the motherboard or find an electronics engineer to replace the failed components, this will probably be more expensive that a new board.
Jun 13, 2012 | ASUS P5GZ-MX Motherboard
I replaced the cmos battery of my asus eee top et1602, now the compunter doesn't boot
cheers
paul
Dec 22, 2010 | ASUS Eee Top ET1602 PC Desktop
No power detect for asus p4s533
clear cmos in motherborad....jumper is near battery....set jumper at 2-3 pin for 5 seconds....and then return it again at 1-2 pin.....if doesnt work,please remove cmos battery and replace new cmos battery...
Oct 15, 2009 | ASUS P4S533-MX Motherboard
Where the @@@@@ is Cmos battery????????
Many laptops use a small, 3 cell rechargable battery. Look for something that looks like a small tube lying horizontally. It will be soldered in if that type. One source for replacements, is www.mouser.com
If a replaceable coin cell, then it will be like a watch batter, and quite visible.
Jun 25, 2009 | ASUS Computers & Internet
Checksum error
Hi robynonis
Yes, definatly the cmos battery. Please make sure you replace with same type battery.
Regards Go-Tech
Dec 22, 2008 | ASUS P4PE Motherboard
CMOS replacement for ASUS d1
It's difficult to say but you will need to remove the underside screws and also maybe even the keyboard as it's often attached to the base. The cmos battery could also be behind the screen. Comment by sandrew, posted on Nov 12, 2006 I'm sorry but I dont have any personal experiences with your particular laptop, but the lcd's are generally held in with 1 screw in each corner normally covered by a rubber bung hiding the screws, I would be very carefull not to disconnect any wires behind the screen, if yor not sure take it to a qualified repairer. You will probably have to remove the top panel just below the hinges as they may be held in underneath
Nov 11, 2006 | ASUS Degatto Notebook
ASUS Z9200 Laptop AC Power Adapter (4.3A 75Watts) by Amstron (Generic) AC Adapter Logo
246 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
