Question about HP Compaq Business nx7010 Notebook
Nx7010 no pae bios
I have a desktop with an amer megatrend bios.I want to get a new bios that works with win 8.1 and needs to have support for PAE,NX.and SSE2
It's best to simply replace the entire Mother Board than try to replace the BIOS. Replacing a Mother Board vs replacing a BIOS is way easier.
Your current BIOS MIGHT work if you can find a flash file for it, but you have to be careful. If the BIOS your flashing isn't in production it's usually only PATCH flash file, to fix a problem with a BIOS, not upgrade it. And if you use the wrong flash file, it will TRASH your BIOS!
The BIOS, which is a chip, is usually micro-soldered to the Mother Board with high precision, by a robotic arm, and not easily removed or duplicated. The exception is if you happen to have a BIOS chip, that can be replaced, in a socket, but this is unusual instead of common.
The best source for BIOS info such as you are looking for is the American Megatrends Website itself at: AMI American Megatrends Inc Aptio (compatible with Windows 8) however their website is for the Mother Board manufacturer so you can't buy the BIOS as a consumer, but through a reseller, AMI Office, Authorized Representatives, etc (AMI American Megatrends Inc How to Buy).
You can however, buy a replacement Mother Board with a BIOS already installed on it (that's the way you usually buy them - with the BIOS pre-installed on the Mother Board) that's PAE, NX, and SSE2 and whatever else you want compatible. A great website to find computer parts and kits, new, refurbished, out of box, etc is the Tiger Direct Website at: TigerDirect com Electronics Tablets Phones Office Supplies Video Games. Just search for BIOS to find your specs, then check the bottom for possible best Mother Board kits to replace the one you have now. Hope this helps. :-)
Mar 03, 2014 | Computers & Internet
Tip
How to make Windows Server 2003 Enterprise Edition see more than 4GB RAM
Issue – After upgrading a server to Windows 2003 Enterprise Edition and adding additional memory, the OS still shows only 4 GB of RAM.
Additional Information – Physical Address Extension (PAE)
In Windows Server 2003, PAE is automatically enabled only if the server is using hot-add memory devices. In this case, you do not have to use the /PAE switch on a system that is configured to use hot-add memory devices. In all other cases, you must use the /PAE switch in the Boot.ini file to take advantage of memory over 4GB.
The newer Dell servers are capable of using hot-add memory devices, but the older servers do not.
If you upgrade an older Dell server and are experiencing the issue above, make the following change to the boot.ini file.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)WINDOWS="Windows Server 2003, Enterprise" /fastdetect /PAE
Add the /PAE flag to the end of the boot device. Then reboot the server.
After rebooting the correct amount of memory should be displayed
To summarize, PAE is a function of the Windows 2000 and Windows Server 2003 memory managers that provides more physical memory to a program that requests memory. The program is not aware that any of the memory that it uses resides in the range greater than 4 GB, just as a program is not aware that the memory it has requested is actually in the page file.
on Apr 19, 2010 | Computers & Internet
Dell Demension e520
These features are a functionality of the Processor used in the Desktop. These features are NOT a feature of the desktop itself and is limited to functionality of the CPU exclusively. Refer to this link for more information regarding NX, PAE and SSE2. http://windows.microsoft.com/en-us/windows-8/what-is-pae-nx-sse2
It is STRONGLY recommended you do not mess with these settings in the BIOS unless you REALLY know what you are doing.
99.9% of the time NOONE messes with these settings you should have no reason to do so.
Jan 08, 2014 | Dell Computers & Internet
Forgotten bios password
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
* Note... You will need to make a bootable Disk with one of these programs on it to fix it.
Good Luck!
Sep 01, 2012 | HP Compaq Business nx7010 Notebook
MSI 870A-G55 MB. Skull 4g 1333 RAM X 2 Athlon processor BIOS reports both stick of RAM but XP OS does not. What up?
32bit XP only supports up to 3.25gb RAM. You'd have to change to a 64bit OS to use the rest.
Good luck.
Mar 24, 2011 | MSI 870AG54 AM3 AMD 870 USB 30 ATX AMD...
Nx7010 does not start.
Hello dear, probably some BIOS values changed, causing u no displays. Try this key combination immediately after startup
esc - loads bios, but not in display
F9 - (hope its F9 in ur laptop) resets BIOS
F10 - saves BIOS to default values and exits
RESTART
Or else try removing CMOS battery, its right beneath the keyboard. (Just remove 1 screw) Remove and hold for 1 minute and then reinsert and turn up laptop on. Your PC should be fine.
Jul 04, 2009 | HP Compaq nx7010 Notebook
Remov pawar on passward
press the relevant key ( F2, Delete ) or whatever it says when you first turn your laptop on to press to get into the bios and login if you need to ( ie if it prompts you ) and you should be able to disable the passwords in the bios
Apr 17, 2009 | HP Compaq nx7010 Notebook
Unmountable boot volume
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
Upgrade Compaq nx7010
go to BIOS setup then press the left arrow keys 2x then press down arrow key2x. then press enter key. you can select the language there.
Jun 08, 2008 | HP Compaq Business nx7010 Notebook
Usb ports not working
You may need to turn on USB emulation in the system BIOS. To do that you'll need to power the system down. When it first turns on you'll see the Compaq logo with instructions to enter setup somewhere on the screen (I can't remember if that model asks you to hit F1 or F2, try both). Once in the "setup" you'll want to look for USB support. More than likely it's going to be in the peripherals screen.
Also, I recommend downloading and updating the BIOS to the newest version. You can get all the downloads for your system on the HP/Compaq website.
Nov 10, 2007 | HP Compaq nx7010 Notebook
HP Compaq Business nx7010 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
