Question about Ricoh Aficio 3232c 3214c 1232c 1224c Oil Supply Unit
Mp 5000 sc 670code - Ricoh Aficio 3232c 3214c 1232c 1224c Oil Supply Unit
Errer code 304 ricoh copier mp 5000
as per ask i know sc 304 is a charge roller problem kindly check the pcu unit or maybe the high voltage
Dec 16, 2013 | Ricoh MP5000
I have aficio MP-5000 what does SC-220 mean
SC-220 = The laser synchronizing detection signal for the start position of the LDB is not output for two seconds after LDB unit turns on while the polygon motor is rotating normally.
Which could mean:
• The Copy Data Security Unit card not installed
• The Copy Data Security Unit card is installed, but it is not the correct type for the machine.
Or a problem with the laser unit itself.
A reboot normally clears the error.
Hope this helps.
Jan 18, 2011 | Panasonic Workio DP-1820E Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh Aficio 3232c 3214c 1232c 1224c Oil Supply Unit Logo
14 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
