Question about Exercise & Fitness
Tread mill will not calibrate
Traed mill will not calibrate(3 stars on the screen)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Need more info? Whats the make, model?
Posted on Jan 04, 2014
5 Suggested Answers
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
SOURCE: treadmill won't run. trys to start and gives up after 1-3 seconds
i am having the exact problem, any answers to this?
Posted on Dec 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
ercupa190
  • 12223 Answers
SOURCE: belt lube flasing on screen the tread mill not working what to do
1) RESET the machine with the reset button.
2) LUBE the machine , this happens to due the lack of maintenance according with the instruction manual, this produce shut down for to protect the electronic system.
see the video and proceed with common sense. Try to RUN the software calibration for easy diagnose, troubleshooting and fix it.
God bless you
Posted on Sep 07, 2012
Star trac E-TRI tread mill when switching on is working but after a minute it went of giving elevation stall,what is the fault?
Hi There, There is a StarTrac service bulletin concerning this issue. This is usually caused by the lower control board. Contact jatinah@rocketmail.com for more help if needed.
Mar 30, 2017 | Star trac Exercise & Fitness
I don't have users manual for pro fitness tread mill keep getting a fault saying E1
https://www.google.co.uk/search?q=Star+Trac+Pro+S+Treadmill+manual&ie=utf-8&oe=utf-8&gws_rd=cr&ei=-N_0VMutKufR7Qb_-IHgDw
youll find the manual
here is the service manual and maintance details you need to do
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20ProTread.pdf
Mar 02, 2015 | Startrac Fitness Products Star Trac Pro S...
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
Belt lube flasing on screen the tread mill not working what to do
God bless you
Sep 06, 2012 | Exercise & Fitness
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
The control panel doesnt function other than to increase and decrease the speed. The tread mill is a Reebok 8700 ES
adjust the reed switch see the diagram attached, clean, and tight the connector very well.
after your fix it RUN the software calibration for easy diagnose and troubleshooting .
see your instructio manual for this if you do not have go www. fitness.manualsonline. com or www. iconservice. com
sincerely. God bless you
Apr 29, 2012 | Exercise & Fitness
Proselect pace master treadmill incline does not work
Dear Sir:
1) You must test the Main motor board, RUN the software calibration for easy diagnose and troubleshooting.
2) The elevation motor has a Potentiomente adjust. 3) The gear from elevation motor can be LUBE. However RUN the s. calibration.
3) Another machine has relais for down and up, you must clean the relais contact, if the board has relais.
Apr 23, 2012 | Exercise & Fitness
Motor getting hot 340 cs
Dear Sir:
Please RUN the software calibration for easy diagnostic and troubleshooting.
Your motor can be defective for various reason;1) ball bearing 2) Brushes 3) winding defective 4) Dirty 5) Lubrication, etc.
sincerely. God bless you.
Apr 07, 2012 | Treadmill Doctor Weslo Cadence 340Cs...
My samsung star s5233a toch didnt work specially the lower bar where contacts menu and are present while the widgets work
you should be able to calibrate the touch screen.
You can calibrate the screen so that your phone recognises the input better. 1. In Menu mode, select Settings → Phone settings → Calibration. 2. Tap the target on the screen. 3. Select Yes.
hope this helps.
Aug 08, 2010 | Samsung Star GT-S5233 Cell Phone
Tread mill is on incline. how can i adjust to a flat position
I am assuming this a Icon product and this is the calibration sequence.
1) Press the Stop and the Speed Up keys down while inserting the safety key. Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 27, 2010 | York Exercise & Fitness
Exercise & Fitness Logo
60 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
