Question about JBL On Stage Micro Speaker Dock for Apple iPod - Aluminum
How to open jbl on stage IIIp - JBL On Stage Micro Speaker Dock for Apple iPod - Aluminum
Nano not compatible with On Stage
It will actually work, however, you will not be able to dock the iPod® Nano into the JBL On Stage™. You can connect the audio in cable to the headphone jack of your iPod. That's the only way, hope this helps. Pls rate solution. Thanks!!
Jun 12, 2008 | JBL On Stage Micro Speaker Dock for Apple...
How can i open the "jbl on stage 400p" for
We just discovered how to break openthis mother. Use a flathead to gently lift the wraparound speaker cover from the lip, and gently work your way around the speaker. Underneath it you'll find a crapload of screws. Then go to town.
Jan 12, 2011 | Harman Kardon JBL On Stage 400P Speaker...
Compatibility issues iPhone 3G - JBL On Stage IIIp
hi there, believe it or not, apple has put a authentication chip into newer devices. It won't allow you to play music or display video on devices that are old. Apple wants you to go out and buy new accessories for the new stuff to make more money. My suggestion is to sell it on eBay and use the money to get a newer compatible dock with your iPhone.
Feb 17, 2010 | On Stage Stands JBL On Stage IIIP Portable...
IPod Adapters problem
just go to jbl's website there download a pdf regarding the dock adapter or 5742d08.jpg
Aug 01, 2009 | JBL On Stage Micro Speaker Dock for Apple...
No Sound from JBL On-Stage 400
The power supply consists of two parts: the AC cord with a two-prong connector on one end and a double barrel plastic connector; and the large rectangular power supply which has a dual prong receptor on the side and a long cable which plugs into the JBL unit.
In my case, I had plugged the double barrel plastic connector into the dual prong receptor backwards. Even though I was getting full power to the unit, this somehow caused the speakers to become inoperative.
Of course, I would offer a recommendation to JBL that their power supplies are made to be "dummy proof" so this does not happen to others as well.
Jul 29, 2009 | JBL On Stage Micro Portable Speaker Dock...
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
Will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Feb 27, 2009 | JBL On Stage Micro Portable Speaker Dock...
JBL On Stage Micro Speaker Dock for Apple iPod - Aluminum Logo
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
