Question about Electronics - Others
Classic USB Drive 64GB not recognized so no format possible
    Champion:
  • 221 Answers
Click the Start button, type power plan in the Search box, then click Choose a power plan.
Next to your currently selected plan, click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings, then expand USB selective suspend settings.
Click Plugged in, then click the drop down menu and select disabled.
If you're using a laptop, click Battery, then click the drop down menu and select disabled.
Click Apply, then click OK.
Posted on Dec 31, 2013
2 Suggested Answers
  • 514 Answers
SOURCE: formating 64gb pen drive
some memory cards / items do not work with FAT32, you should try to re-format using your PC to FAT16 format.
Posted on Dec 31, 2008
PNY 64gb attache is not recognized
Is it a usb3 device? and does your computer have usb3 ? Also a non formatted device will show up as a drive or device in device manager but not in my computer until it is formatted and if it wes formatted and working previously the FAT my be corrupt and require reformatting assuming the device is not damaged
Jan 29, 2018 | PNY Attache 64GB USB Flash Drive
HOW TO FORMAT USB PNY 64GB
You can simply go to my computer, right click on the usb drive, and pick format. There, you can format your stick quite easily. I suggest for you to set it to FAT32 and pick quick format and it should be done within seconds/ a minute
Sep 17, 2013 | PNY 64GB Drive
Usb drive not recognized
There should be some virus in your USB drive which is not okay. Please Check it and format it then it will work otherwise that's the problem with the hardware(USB disk)
May 01, 2013 | Pioneer Audio Players & Recorders
How to format Sony 4 GB USB in FAT or NTFS after fail to Format?
You should be able to by going to my computer, then right clicking your USB device and either FORMAT or go to properties and on the tabs select tools and error check. You may have the possibility to Format there as well. If that fails I suggest downloading a separate program in linux, such as Hirens Pack...They have Hard Drive/Memory specific program applications + plenty of DOS applications at your fingertips for just about everything else...just be very careful which ones you choose to mess with. Only for advanced users. Hope this helps
Feb 21, 2013 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
I don't formats my kingston 64gb pen drive
Hi kingkumarae,
Due to viruses , the drive cannot be formatted in many cases, however if you want to format it ,
I would recommend that you restart your computer and plug in the pen drive and then do not autorun it.
When you do that , you can right click on the drive that you find in my computer and then rightly click on select format option, and then you can format your drive.
If this does not work in your computer you can possibly try it in your laptop using the same procedure.
Hope this helps ...:)
Sep 04, 2011 | Kingston DTU30G264GB DataTraveler Ultimate...
The 64gb flash disk is missing a file system
This means that the flash drive needs to be formatted. If you had data on it and it is now doing this out of the blue than it is probably broken.
If you need to format it do the following
plug it in to your computer, go to my computer, right click the flash drive and click format
WARNING THIS WILL WIPE WHATEVER DATA, MUSIC, PICTURES, ETC. YOU HAVE ON IT OR ANY OTHER DRIVE YOU TRY TO DO IT ON.
Dec 12, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Plug into USB port... recognizes device when I click on it from my computer tells me to format the drive... I try but the format fails.?
Is your usb drive locked? The micro vault classic has a lock switch on it. This prevents you from writing data to it. Please make sure that is not in the lock position. Then plug it back into your pc and you can go ahead and format it.
Mar 18, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Formatting pen drive 64gb
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format pen drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 22, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Unable to format 64 gb kingston pen drive
These are actually ccore flash drives, shipped with the name "Kingston". YOU CAN FORMAT ANY ZIP DRIVE WITH "HP USB DISK STORAGE FORMAT TOOL". Trust me, it really does the needful. I had the same problem earlier =)
Feb 12, 2009 | Computers & Internet
Electronics - Others Logo
37 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
