Question about Iomega Computers & Internet
External hard drive not visible
Iomega 31803800 is not visible
lifebyguitar
  • 57 Answers
SOURCE: iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Posted on Aug 09, 2009
Crankstart
  • 696 Answers
SOURCE: Is it possible to open my Iomega Prestige 1 TB USB
Yes it is possible but the Iomegas are difficult to open and you often snap the plastic retainers in the process. Given you can buy a !TB comlete for only about $20 more than buying the raw drive I suspect you would be better advised to simply replace the unit all together,
Chris
Posted on Aug 30, 2009
  • 29 Answers
SOURCE: Iomega large external hard drive doesn't show up
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Posted on Sep 13, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
SOURCE: my iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Posted on Jun 21, 2010
Where can i find a manual
I couldn't find a manual but maybe asking the proper question about your Iomega Hard Drive someone might get you an anser.
Most common issue is that it is not recognized so here uou have some solutions:
My iomega external hard drive not showing up in my computer but does...
iomega HDD external drive not detected LED comes ON but wont run SOLVED
Windows 7 help and support forum
External Hard Drive Not Showing Up
Aug 13, 2015 | Iomega Computers & Internet
Win 98 Drivers for Iomega Prestige 1 Tb external drive
Windows 98 does not have an USB driver, You may get one from the Iomega WEB site for this external hard drive.
Feb 05, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have a Iomega 500G portable hard drive RPHD-U, when I plug the USB 2.0 in I hear a clicking noise on my HP computer. The portable haed does not show up in the my computer devices. This device use to be...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Jan 08, 2011 | Iomega eGo Portable Hard drive 500 GB ...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
My iomega 500gb external hard drive has a broken.
Apr 03, 2010 | Iomega (33654) Limited Edition 500 GB USB...
Trouble Saving to my Iomega External Hard Drive
Some versions of xp like to set permissions excessively, check security settings
Mar 14, 2010 | Computers & Internet
External hard drive will not mount on my mac
Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
Sep 21, 2017 | Iomega 33089 250 GB Hard Drive
Iomega external not visible
Aug 08, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
Computers & Internet Logo
19 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
