Question about Weslo Cadence G 5.9 Treadmill
Ticking sound on new cadence 5.9 treadmill - Weslo Cadence G 5.9 Treadmill
Strange Clicking
You have a minimum 90 day warenty,normally one year.Take the unit back and get a new one.This is why you get a warnty with things you purchase,so if anything goes wrong,you can get it replaced.Or repaired,your option.
Apr 14, 2014 | Weslo Cadence G 5.9 Treadmill
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Nov 15, 2010 | Cadence Exercise & Fitness
Need a new saftey key where do i get one
Call Icon Fitness @ 1-800-999-3756 Description: KEY/CLIP Part# 155398 Price $2.38
Jul 31, 2010 | Cadence Weslo 620/630 Treadmill Walking...
I have a weslo cadence 200 cs treadmill. I changed the batteries but the display keeps blinking 0
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
May 20, 2010 | Exercise & Fitness
Lost the key to my weslo candence ct 4.8 treadmill how do i get a new key or get it to run
Call Iconfitness @ 1-800-999-3756
Part #: 208603
Part Name: KEY,CORD/KEY,ASSY
Model: WLTL243080 - WESLO CADENCE CT 4.8 TREADMILL
Part List: #208603 - KEY/CLIP
May 15, 2010 | Weslo Cadence CT 4.8 Treadmill
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence G 5.9 Treadmill Logo
19 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
