Question about Saeco Coffee Makers & Espresso Machines
Hd8751 green display wont light up
Green display won't light...not even a year old!!!
SOURCE: flashing green light
I had the same problem due to power surge.Repairman came and said power board replacement might fix--$300 parts and labor, but if DM module is damaged, another $600-700. My set is 5 yrs. old. I'm shopping for a new LCD.
Posted on Jan 09, 2008
dsacco86
  • 1077 Answers
SOURCE: Dynex 37'' LCD TV (DX-LCD37-09) wont turn on
The registration card may help with warranty going through the TV company. But, that's the last option.
You can fix it yourself by replacing this board. The board number should be BA71G0F01043.
The 8 Inverter transformer are the problem. They are on many TV power boards that are causing the same problems.
Ebay is selling a couple for $49. Good price I think.
http://www.google.com/products?sourceid=navclient&rlz=1T4GGLL_enUS311US314&q=dx-lcd37-09+inverter&um=1&ie=UTF-8&ei=oRf9SYKIG5_aswOMoPTjAQ&sa=X&oi=product_result_group&resnum=1&ct=title
If you decied to throw the board in the trash, let me know. I maybe able to help you fix it so you can have a spare board. I fixed mine that way.
Posted on May 03, 2009
SOURCE: tv red blink no start42 plasma philips
Thank you for the help. I actually changed the whole main power supply board and it still did not fix the problem. When I put the new one in, I had the tv on for about 3 hours and then I shut it off. No sooner did I get it back up on the wall and the problem started all over again.When I pulled the original board, the caps all looked fine so I am not even sure the board is bad. Problem is there is no one around me to test it. I am not going back to the same shop that already told me that it was a bad main power supply board. Any other suggestions?
Posted on Jun 25, 2009
  • 95 Answers
SOURCE: Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Posted on Sep 27, 2009
  • 188 Answers
SOURCE: no display on PSP screen but light is green
It's BRICKED!
You'll need a Pandora Battery + Magic MS!
Posted on Oct 25, 2009
Testimonial: "Because of this tip, I immediately went to a repair shop and followed what KKK999 suggested and I told this to the technician and lo my issue solved!"
I own a Philips Saeco Intelia Espresso coffee machine Type HD8751. It is operating fine, in terms of coffee making, but for some reason it has just started displaying in 'black standby mode' rather than...
Not a solution as such but my Philips Saeco Intelia HD8751 has developed the exact same fault and is about 8/9 months old. The machine is being picked up in a few days to be repaired by Philips under warranty. I can only suggest you contact Philips for a repair as this is obviously a product fault.
Aug 27, 2013 | Coffee Makers & Espresso Machines
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
Mar 20, 2013 | Mitsubishi LT55164 Unisen Medallion 55...
The green light on my prince lionheart warmer won't stop blinking
I realize the original question is 2 1/2 years old but for future answer searchers... the flashing light means your power cord is no longer working.
Jan 18, 2013 | Prince Lionheart Premium Wipe Warmer
Absolutely no electrical power tried to jump start thought it might be battery that did not work wont even crank over no dome lights nothing
Are your cable connections clean ? in the meaning of is there visable green corossion on the battery post? Some time if there is after you clean them good the green stuff grows done into the cables a inch or two,this will stop a good connection. Check your connection at the starter also the green stuff will grow there also,,Check your ground Blk cable also make sure they are tight and clean. and yes this green build up will stop a jump too.And it will eventually make your battery go bad because it will stop it from receiveing a charge from altenator
.Lets say your cables are clean as a whistle,Your battery can go out just like that if its over 3 or 4 years old.Iv had it happen to me on a car that was only 4 years old.
Mar 11, 2011 | 2000 Chevrolet Blazer
Was never open for over a year. started ip up it went through some pace. printed an alignment sheet. screen flickered and now does nothing. it's getting power. the green light comes on and disappears. then...
well it sounds like it may be a defect that was undetected since you never used it, unfortunately the manufacturer wont do anything out of warranty.
If the green light is going off then you have an internal power problem.
Mar 31, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
The screen is black even though the green light is on
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Plasma with green tint
Could be a main board.Tuner could be bad.
Dec 24, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
