Question about Nextbook Premium Series Next7P12
Can't connect it to computer via usb
Hi there - my nextbook 7p12 won't connect to computer via USB? HELP!? I've tried all I know to get it done. Can you help me please? USB is fine and not damaged, other USB cords also used in port and they all work when plugged in. Does not seem to want to bring anything up or recognise new hardware being plugged in. Can you help me if possible.
I cannot turn on or off my jelly bean with the button.it does not stick out as normal it is flush with the machine
Posted on Dec 30, 2013
My nextbook ares 10l keyboard stopped working
If your USB Keyboard stopped working, you can try to disconnect it and connect it back on the fly. USB connections are plug and play, so if you are running Windows and your USB keyboard doesn?t work, you can try unplugging and plugging it back to re-establish the communication, or simply try connecting it to another USB port. If this still doesn?t work, check the led lights on the keyboard; are any of them on? If they are, is the computer acting slowly? You may need to restart it at this point to refresh your computer memory and resources to get it back to normal speed, or perhaps it needs maintenance by running disk cleanup and defrag it
Nov 28, 2016 | Nextbook Tablets & eReaders
What is the Mac address and the ip address for nextbook. 7"tablet model #Next 7P12-8G
Every device has a different MAC address. Usually it will be found either on the back of the unit, on the box, or you can check the network settings, The IP address will change depending on the network you connect to in most cases as the standard settings are typically DHCP which means the computer gets the address from a server on the network. If you check in settings you should be able to see it,
Aug 14, 2015 | Tablets & eReaders
How to connect a usb powered sound bar to aNextbook
I don't think you can. Your battery would last 15 minutes.
Also There would have to be an amplifier in your nextbook which is hardware and unlikely to be there without it being mentioned by the manufacturer.
Sound comes from the 3.5 mm analog headphone port which takes milliamps of power.
Mar 14, 2015 | Nextbook Tablets & eReaders
How do I connect a flash drive to my 8.1 nextbook
Well, you might need to find a usb to microusb adapter, so it will fit in your tablet.
Dec 01, 2014 | Nextbook Tablets & eReaders
How do I download a file from my PC to my Nextbook 8? I would like to download a pdf file to my tablet, but I do not know how to do so.
Use USB port to connect. Click on file you want to download. Send it to the USB port. Open USB port to find it. You may want to change the name of the file before you begin to download it.
Oct 16, 2014 | Nextbook Tablets & eReaders
How do I connect NEXT7P12-G to bluetooth keyboard?
It looks like your tablet is not Bluetooth-enabled, in which case you cannot connect the Bluetooth keyboard to it. You may try to connect a regular keyboard via the USB port on the tablet (although I believe that USB port may accept only flash drives).
http://www.nextbookusa.com/pdfs/Next7P12-8G%20Tech%20Spec%20102412.pdf
Sep 07, 2014 | Nextbook Next7P 7" Tablet
Teardown of nextbook 7p12-8g
You will need to get it repaired or replaced by a reputable repair shop, it may be cheaper to get a new one
Apr 19, 2014 | Nextbook Premium Series Next7P12
I have a nextbook 7P12 and it won't turn on. I have charged it as I thought the battery was flat. Now it won't turn on and I'm stuck as what to do. Anyone know how to fix it? Thanks
The Nextbook tablet can be turned on by pushing down the volume button and the power on and off button at the same time, hold down a few seconds and wait. It should turn on again. It always works for me.
Sep 22, 2013 | Tablets & eReaders
How i make my usb discoverable and show usb storage mass when i connect to computer
Typically the tablet will pop up a notification when you plug it into a computer asking ho to connect it. If not, you should be able to specify a default option under settings > connect to PC. Your menu may be different.
Jul 06, 2013 | Toys R Us Tabeo
Nextbook Premium Series Next7P12 Logo
123 people viewed this question
Top Nextbook Tablets & eReaders Experts
bigdawg7299
Beej West
Level 1 Expert
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
