Question about Camping, Backpacking & Hiking
I took apart my kershaw brawler and was wondering if anyone had a video or step by step on how to put it back together with the torsion bar in place
SOURCE: putting back together the trimmer
I Need to kno a answer to this as well
Posted on Apr 25, 2008
SOURCE: Bonavita crib
I had the same problem. Send an e-mail to receptionist@lajobi.com with the make and model of the crib and they will e-mail you instructions.
If you need replacement hardware, they can also take care of it.
Posted on Jun 11, 2008
Molson02536
  • 3854 Answers
SOURCE: want to change torsion bar keys
The torsion keys are supposed to give 2-3" additional drop vs.the "free" method. I know adjusting the torsion bars kills the ride but how bad is it and how far can you go???
Believe, 15/16 socket would be the correct size. Also, be aware that they are probably pretty rusted and VERY hard to turn at first. Air tools do no good, so you'll need a 1/2" drive breaker bar and a long pole to put on the end. This is the fastest way to get the torque you need to break those suckers loose.
I suggest measure and writing down the height about 3-5 spots on each side, whether it be the frame, body, or whatever. Crank each side a few FULL thread turns, then measure again. Once you get about the height you want, measure both side to make sure they're equal. After that, it's best to get a full alignment as some of the suspension will now be at different angles (of course).
Posted on Apr 19, 2009
wrench57
SOURCE: putting my airgun back together
http://www.flickr.com/photos/wrenchmonkey2k/
Posted on Jul 21, 2009
shadtremonky
  • 353 Answers
SOURCE: how to put a steering wheel back together
special tool required
Posted on Aug 07, 2009
How to install trunk lid torsion bar on 2008 Honda Accord sedan
most torsion bars ure under the least tension when fully open and have one bar facing right and one left
insert the fixed end in the bracket then with a suitable tool twist the end of the bar down as you put it in the hinge bracket repeat for the opposite bar
It is not easy until you get the idea as to how to twist the bar as you put it in place
Mar 23, 2016 | 2008 Honda Accord
Frozen Beater Bar
I expect the brushes/bar are removable. the man manufacturers can come up with some realyy ingenious ways of putting thier machines together!
Jun 19, 2017 | Bissell 6594 PowerForce Bagless Upright...
I took apart my PS3 Dual shock 3 controller and painted up. When i put everything back together and I tried turning on the PS#3 but it wouldn't turn on. When i was putting it back together it kept turning...
i would suggest reversing the steps you took and look for anything you missed or improperly placed components because you said it kept turning on so something got pressed together improperly and is giving you the negative results your having im sure you will figure it out
Dec 30, 2010 | Sony Dual Shock 3 Controller for...
Looking for a manual for a ab and back plus body by jake
You can use the Body by Jake Ab and Back Plus to target and tone your frontal abdominal muscles, waist and rear obliques and to strengthen the muscles in your lower back. The exerciser comes with torsion disks that allow you to vary the level of resistance. Use one disk if you're a beginner, two disks for an intermediate level workout and three disks for an advanced workout. There are only four exercises to do, known as the "Fit Four." With consistent workouts you'll begin to see results and feel stronger in your core.
Step 1
Align the arrow on the handle bar with the arrow marked "Ab" on the exerciser and place a disk in the hex shaft.
Step 2
Seat yourself comfortably and place both your feet under the ankle pads.
Step 3
Do the Abdominal Crunch. With your elbows at your side, grip the handles, curl your body forward in a controlled manner and then return to the starting position to complete one repetition. Contract your abdominal muscles when curling forward, making sure the movement comes from your abdominal muscles and not your arms. Do 15 to 30 repetitions.
Step 4
Do the Side Twist. Bend your legs, raise your feet and cross your ankles in the seated position. Hold the handle bars firmly and swing your lower body from the right side to the left, making sure you move using your oblique muscles. Your upper body should be kept as stable as possible. Movement from right to left completes one repetition. Do 15 to 30.
Step 5
Do the Oblique Crunch. Position your seat slightly to the left. Place your feet in the left ankle support pad. Put your knees together, grip the handles with both hands and curl forward slowly. Return to the starting position and repeat 15 to 30 times. Now angle your seat slightly to the right, place your feet under the right ankle support pad and repeat the exercises for your other side.
Step 6
Do the Back Extension. Remove the torsion disk and align the arrow on the handlebar with the arrow marked "Back" on the exerciser. Place a torsion disk back on the hex shaft. Sit comfortably in the seat with your hands gripping the handles and your feet under the ankle support pads. Ensuring your back is pressed against the upper pad, lean back slowly and then return to the starting position to complete one repetition. Repeat 15 to 30 times.
Step 7
Perform the exercises in the following order to complete one circuit: Abdominal Crunch, Side Twist, Oblique Crunch and Back Extension. Once you have completed one circuit, do another circuit from the beginning.
Step 8
Work out for 10 minutes at least three times a week. As you become stronger in your core and can comfortably complete 30 repetitions of each exercise, add another resistance disk.
Tips and Warnings
  • Before you begin exercising, warm up and stretch for five to 10 minutes. To gain maximum benefits, don't rest between exercises.
  • Ensure the torsion disks are placed correctly on the hex shaft; the slot on the torsion disk should be aligned with the round rod. Consult your health care provider before starting any exercise program to prevent the risk of injury.
Read more: http://www.livestrong.com/article/40450-use-body-jake-ab-back/#ixzz2GCOW86kL
Jun 25, 2010 | Exercise & Fitness
Where can I find a schematic and detail strip instructions in order to completely disassemble my Kershaw Leek for cleaning?
there are several videos on you tube and torsion bar kershaw will do they are basically all the same. very simple take your time dont force anything watch videos several times if you have to
Mar 25, 2010 | Kershaw Knives Kershaw - Leek Series...
How to adjust a torsion bar
Step 1 Jack up the vehicle on the wheel to be adjusted, and set the frame rail onto a jack stand. This is to release the stress on the torsion bar so it can be adjusted easily.
  • Step 2 Crawl underneath the vehicle and locate the torsion bar mount on the frame. There will be a bolt in the center of the mount, pointing upward. This is the adjusting bolt, and it will accommodate a large-sized socket driver.
  • Step 3 Adjust the torsion bar. Turning the adjustment bolt clockwise will tighten it, raising the amount of load that can be placed on the bar. This will raise the vehicle when it is taken off the jack stand. Turning it counterclockwise will lower the available spring rate and cause the car to sit lower. Turning it too far in either direction can cause problems, so follow the specific vehicle's manufacturer guidelines when making wide adjustments. Normally, only one full turn will be enough to give the desired result.
  • Step 4 Lower the vehicle, and check the clearances of the frame to the ground. They should be the same for both sides. If they are not, then more adjustment will be necessary to the torsion bar adjustment bolts.
  • http://www.readylift.com/t-torsion_bar_keys.aspx
    Mar 13, 2010 | 1994 Chevrolet S-10
    Took torsion bars off kept them in the crossmember and when i went to put them on I had no weight on the front and tightened the bolts half way and let the truck down and it sank to the bump stops its a 95...
    Did you put the adjuster back at where they were before you disassembled it? Are you sure it wasn't on the bumper stops to begin with ? Does it look like the ride height is lower than it was ? If everything is together the way it should be and you have the adjusters at there max adjustment then your torsion bars are probably shot.
    Nov 17, 2009 | 1995 Nissan Pathfinder
    I took my ds aprt put it back together and no power on?
    Oh... Taking your DS apart is a huge no no! Only professionals should take apart your DS. That goes for other items as well.
    I suggest that you take it to a professional and have your DS refurbished. Refurbishing makes your DS like new, and can cost anywhere from $70 - $90, depending on where you take your DS to be refurbished.
    Hope it helps~
    Jan 19, 2009 | Nintendo DS Lite Console
    Machine foot will not work
    Have you taken the foot control apart yet? What have you got to lose. Possibly something came loose that you can put back in place? There are small carbon contacts that may be put back in place. Just remember to put it back togeather the same way you took it apart. Or keep an eye on eBay and ask questions. Mostlikely a generic footcontrol will work. Good luck. Rick
    Aug 20, 2007 | PfaFF Tiptronic 2040
    Camping, Backpacking & Hiking Logo
    266 people viewed this question
    Top Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
