Question about Baby Gear
Swallow apollo manual
Removed all covers to clean. Having problem putting back together
  • 76 Answers
SOURCE: My roommate removed the water in hose and I need to find a manual to put it back together
starslight07 You can find the repair manual for your washer here: http://tinyurl.com/32d5lu Good luck. Gendos
Posted on Jul 07, 2007
  • 4090 Answers
SOURCE: how to put the rival soft serve ice cream maker back together after cleaning it
see how much appreciation there is for helping some people? Havent even got the courtesy to provide a rating or a thank you for the effort to help them!
Posted on Oct 16, 2009
ZJLimited
  • 17970 Answers
SOURCE: Motor stopped running. Have
Why take off the motor? Sned us the brand and model.
Posted on Oct 19, 2010
  • 19 Answers
SOURCE: the chain will not slide
When a chain comes off a bar during use, sometimes the chain will strike the bar and/or the chain guard (piece on the bottom of the saw where the chain goes back around the sprocket, that keeps the chain from hitting the user) and this will put burs on the drive links (parts of the chain that ride in the groove of the bar). These burs will cause the chain to grab onto the side rails of the bar when reinstalled onto the bar. The only way to correct this is to file the burs off of the drive links or replace the chain.
You can find flat files to file off the burs at your local hardware or building supply store and replacement saw chain loops at Partsbuggy.com.
Posted on Dec 14, 2010
small6363
  • 18392 Answers
SOURCE: Im having a hard time putting it back together after cleaning filters
click the link below for the manual that wil give you full instruction for filter changees,,
http://uk.bissell.com/images/UserGuides/6594.pdf
Posted on Sep 05, 2012
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
I completely took apart my holmes air purifier to do a deep cleaning to get the fans and evreything dust free. need diagram to put back together. HAP9422 (model)
Hello, this is Ava with Think Crucial.
This is the manual of your Holmes model number: Holmes HAP9422 Product Manual Hope this was helpful.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
Ava B.
Think Crucial Customer Care
Apr 09, 2015 | Holmes Products Air Purifiers
How can I get the case of my singer confidence open
If you take a look at the left hand side, the cover there (over the needle post) usually has a screw in the side which is often covered by a white disk that you can pop out by pressing on one side with a screwdriver, and another at the back that is generally not covered. It may only have one screw in the back. That cover can be removed for cleaning purposes, and you should remove it periodically to clean it. If you want to uncover more than that, generally you would remove the back first, but if you do, tape each screw next to the hole on the cover--it will save you a LOT of grief putting it back together!
Jan 17, 2014 | Singer Featherweight II 117
Need reassembly instrucstions on American Standard ToeTap Drain
buy another one and use it as a model to put yours back together then take it back for a refund.
Dec 24, 2013 | American Standard Plumbing
FZDC47100w
we had the same problem and didnt use our's for about a year as a result! brought it to a guy in Cork Street, Dublin. what he did was clean out the pump area on the left hand side, near the back and at the bottom of the machine. having cleared out the fluff and dust he washed it out, flicked some sensor switch a few times (under a small plastic cover he had removed on the pump unit). when he put it back together it worked fine.
Apr 19, 2012 | Zanussi TC7102W Electric Dryer
My ps2 is the thicker one, it has quit readung dvds and allbut 3 of my ps2 games,it won't even read a laser lens cleaner
Hi, this happened to me once. What i did was remove the top cover of the ps2, carefully removed the power button from the cover, i removed the cover from the lens and i carefully cleaned it manually with a cloth... then put it together just like you took it apart, worked great for me
Dec 24, 2010 | Sony PlayStation 2 (PS2) Console
ZODIAC INGROUND POOL PUMP MAKES A NOISE BUT DOES NOT PUMP WATER. WAS WORKING AN YESTERDAY. HAVE CLEANED FILTER, AND MANUALLY TURNED FAN AT THE BACK. STILL NOT WORKING??
If your pool pump is acting sluggish it may simply be a build up of debris inside the impeller. Cleaning it is simple if you know how.
Step 1 - Check the Impeller
You can check the impeller for clogs by opening the clear cover that is on the strainer basket. Then place your garden hose into the basket and turn it on high. The water should disappear immediately. If it does not, you may have a clog.
Step 2 - Turn off the Power to the Pump
Before actually removing the clog from your pool pump impeller you will need to turn off the power to it. Remove the basket and use a finger to reach into the hole behind the basket to feel for any debris. If it is clogged, go to step 3.
Step 3 - Disconnect the Pump and Motor
Disconnect the pump and motor from the plumbing. Depending upon the make and model of your pool pump you may be able to skip this step. The motor usually just slides away from the pump.
Step 4 - Remove the Plastic Cover
Take the pump apart by removing the plastic cover over the motor. This cover generally has several small screws holding it on.
Step 5 - Remove and Clean the Impeller
Once the cover is removed you will easily be able to see the clog in the pool pump impeller. Just use your fingers or a coat hanger to clean it out.
Step 6 - Clean
Put everything back together. Once you have it cleaned out you can put the cover back on and put it all back together. Problem solved.
Dec 10, 2010 | Plumbing
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Jan 04, 2009 | Singer 8280 Mechanical Sewing Machine
REDDY HEATER PRO 70
I have a Reddy Heater R100 that ran just fine until one day it
wouldn't ignite. I took the cover off to see if it was sparking and it
ran just fine with the cover off. I got on the Internet to see if there
was a definitive answer as to why it would only run with the cover off;
there wasn't. So I decided to troubleshoot it step by step instead of
replacing everything at once. You can thank me later.
Step 1: Dumped out old fuel, made sure the tank was completely dry and
clean. Put in fresh kerosene. This is an absolutely hideous job.
Result: Still would only burn with the cover off. Said bad words.
Step 2: Replaced all three filters. Result: Still would only burn with
the cover off. Didn't say bad words, just thought them.
Step 3: Removed the end filter cover and pushed on the pressure relief
ball. It seemed to be stuck.
so I marked the relief screw, counted the exact number of turns to take
it out, and washed the end filter cover and small parts with Dawn
dishwashing detergent. Harsh solvents can melt the plastic on the end
filter cover. Blew everthing dry. Put a little oil on the spring and
ball so they wouldn't rust. Put the relief screw, spring and ball
together, making sure I turned the screw back in the same number of
turns that I took it out with, within a tolerance of about 1/8 turn.
Step 3: Downloaded a manual from:
http://www.desatech.com/manuals.cgi?products=Construction%20Heaters to
find out the spark plug gap. They didn't have one for an R100 so I used
the one for a R100EDI. I cleaned and set the spark plug gap to .055".
I think later heaters use .075" or .085". Check your manual. Result:
Step 4: Removed the nozzle. Put a clean paper towel under the input and
sprayed carburetor cleaner into the output end of the nozzle,
backflushing it. Four or five pieces of crud came out, onto the paper
towel. Really cleaned the nozzle good. Blew it off with compressed air
to make sure all of the carburetor cleaner was evaporated. Replaced the
nozzle. Result: O frabjous day! It worked just fine for about a half
hour, then it started coughing and smoking.
Step 5: Removed the nozzle again. Put a clean paper towel under the
input and sprayed carburetor cleaner into the output end of the nozzle,
backflushing it again. Four or five pieces of crud came out, onto the
paper towel, again. Really cleaned the nozzle good, again. Cleaned the
fuel filter and the upper fuel line. Made sure everything evaporated
before I put it back together. Result: works great with the cover on.
Ran the tank of fresh fuel empty. Put the original fuel back in, it
works too.
So, if in the future, I have the problem where it doesn't burn with the
cover on, I'm going to start with the nozzle, upper fuel line and fuel
filter.
Dec 20, 2007 | Reddy R70ET Utility Heater
Jul 06, 2007 | Whirlpool LSR9434PQ Top Load Washer
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
