Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Espresso does not make
Hello
My stabucks barista espresso coffee machine approx. 3 1/2 yrs old. Steams milk ok, starts to make espresso and than stops. Can you help me.
Laura Bowman
lbowmanid@yahoo.com
Solution #1
posted on Jun 29, 2009
Rank: Master
Rating: 85%, 2 votes
Does the water stop while the pump is still operating ? Is the "READY" light ON when the water stops ? You need to be more specific about exactly what the symptoms are because these machines are fairly complex and have pressure and temperature sensors to make sure the shots are consistently good. You should make sure to flush your machine regularly with descaler because scale buildup is the most common problem that you'll run into with coffee machines. You can get descaler at any decent hardware store or you can also use "CLR" which works just as well.
If the pump keeps running and the water flow just stops, then I would suspect that there is a clogged line or the grind is too fine. Try pouring a shot without using the spoon to see if the water flows freely. If it flows OK, then your grind is probably the problem. If it still does not flow freely, descale the machine several times and see if that makes things better. If you've never descaled your machine, then use a strong descaler or CLR concentration and run the descaling liquid through the machine several times, or even let the descaler sit and soak the inner workings overnight, If the just pump stops prematurely during a shot, then there is probably a sensor problem with the machine. Take it in to a repair place for diagnosis. If you can't find a place that repairs espresso machines, ask the manager of your local Starbucks what repair company they use, since Starbucks stores have contracts with people to routinely service and repair their own equipment.
Solution #2
posted on May 20, 2009
Rank: Guru
Expert
Rating: 86%, 382 votes
Remove the portafilter and press the brew button, if the water flows from the head with a nice flow then the problem is with the grind (too fine), or the coffee has been Tamp too hard.
If water barely flows when you press the button then try backwashing the machine and removing the shower screen to clean it.
Popular Solutions for Coffee and Espresso Makers
Saeco Starbucks Sirena Espresso Machine
1 Solution
Braun Tassimo Espresso Machine & Coffee Maker
1 Solution
Questions and Unsolved Problems for Coffee and Espresso Makers
I'm coffee lover and want to buy a coffee espresso maker in the price range between $600.00 and...
(More)
I'm coffee lover and want to buy a coffee espresso maker in the price range between $600.00 and 850.00.I live in Panama Central America. Can you suggest a maker and model???
Tkanks,
Boris Allara
b.allara@gmail.com
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
When I pour the water in the top, it doesn't come out as quick and overflows in the plastic housing...
(More)
When I pour the water in the top, it doesn't come out as quick and overflows in the plastic housing and comes out of the weep holes in the back of the unit. I don't have a long enough cleaning spring that comes with the unit. Is there a solution I can pour in to clean the tube.
we have it set on a timer to go off in the morning.we never over fill it but it over flows all over...
(More)
we have it set on a timer to go off in the morning.we never over fill it but it over flows all over the counter.it has happened a few times.
The machine stopped mid-way through the brewing cycle. #26 led is blinking. I removed the brew group...
(More)
The machine stopped mid-way through the brewing cycle. #26 led is blinking. I removed the brew group but the machine won't reset. I tripped the microswitch in the back but nothing happens, no motor noise.
