Question about Ovens
Defy gemini oven. My bottom oven keeps on tripping the electricity when it on for 5 minutes. I thought it was the thermostat but I have just replaced it. What else could the problem be. Anton 0729931963
  • 491 Answers
SOURCE: Last night the cooker rcd tripped. On resetting,
SOUNDS LIKE YOUR BOTTOM HEATING ELEMENT HAS BURNT OUT AND IS PROBLEY CAUSING A TRIP.
Posted on Oct 21, 2009
barkencoa
  • 3463 Answers
SOURCE: belling oven xou592 bottom fan oven not heating up
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Posted on Dec 16, 2009
Testimonial: "Thanks very much , wasn,t sure whether thermostat could be at fault so this has helped. Will buy an element and fit and let you know outcome. Thanks "
SOURCE: i have a defy gemini petit chef multi function
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Posted on Jun 21, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidaire Gallery Series Electric Oven has
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Aug 07, 2010
Testimonial: "thanks i will have my husband look into that. "
HansPP
  • 2510 Answers
SOURCE: My Defy 621 stove causes the earth leakage to trip
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
Posted on Jan 16, 2011
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
Bottom oven does not work tim eflashes and gives 0-.-7
Child lock is activated go to http://www.defy.co.za/images/manuals/OPERATING%20PROCEDURE%20FOR%20DEFY%20GEMINI%20%20OVEN%20%206%20BUTTON%20CLOCK-TIMER.pdf last page.
Apr 12, 2014 | Ovens
Bosch HBN7052 - main fuse tripping even after replacing the heating element
It appears there is too much current (electricity) being drawn towards the element, seeing once you replaced it, it worked fine for 5 minutes and then tripped again...I believe the problems lies within the wiring going towards the element, or the thermostat that controls the amount of current coming towards the element. Instead of turning off at a desired temperature, its not and continuing to heat up to the point of tripping the fuse. Try replacing the thermostat.
Dec 01, 2013 | Bosch Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
Jan 16, 2011 | Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
82 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
