How To Replace Kyocera Taskalfa 180 Copier Drum
I need to replace Kyocera Taskalfa 180 Copier drum with new drum. Drum unit is in my hand. I want to know how to take-out drum from drum unit to place new drum.
    Sergeant:
    Champion:
  • 317 Answers
Hopefully this will help.
Source:
http://www.manualowl.com/m/Kyocera/TASKalfa-180/Manual/345566
Posted on Dec 30, 2013
Testimonial: "operation guide will not show the way of replacing drum..."
  • Chathura Prasad Kudalugoda Arachchi
    Jay Arias-Chavez, operator manual has no information about this subject...Useless.
4 Suggested Answers
  • 92 Answers
SOURCE: Average useful life of Sharp AL-1661CS
With that machine the toner cartridge also contains developer. Without getting too in depth, it sounds like maybe your toner cartridge is leaking a bit of developer which takes with it a bit of toner. Developer is made up of tiny metal particles which are supposed to stay inside the developer unit. As the seals wear in the developer unit (which is part of the cartridge) it allows a little to leak out causing the problems you are seeing.
When you take the toner cart. out, at the rear side (part that goes the furthest into the machine) you'll see a white foam seal. If you notice some excess toner (and probably developer) sticking straight out from that, it could be that the seal has a jagged edge which is dragging developer off of the magnetic roller and depositing it on the drum making the line you speak of on the left hand side.
Also check to make sure the copier is sitting level, if it's not then the concentration of toner at one end of the developer unit is too great and some can be allowed to spill out.
So in short, it's probably not the drum that's at fault, it's more likely the toner cartridge.
Is it worth replacing? There's no easy way to answer that. If the machine is used in a fairly high volume workplace, it's probably worth replacing. If you could get by with a smaller cheaper machine (brother, HP, lexmark etc.) that does printing, scanning, faxing and copying you may be better off.
Posted on Oct 16, 2008
  • 40 Answers
SOURCE: Kyocera 1810 drum replacement
If you have some mechanical skills and a steady hand you can change the drum. However it worth the money to pay a "pro"to do it. Also you may want to replace the cleaning blade too.
1. Open the front cover - where the toner is.
2. Remove the black cover - 2 screws
3. Remove a little stopper at the bottom of the drum unit + 1 screw
4. Disconnect the drum unit cable.
5. Take off 2 screws which secure the Drum Unit.
6. On top of the Drum unit you should see 2 white plastic stoppers - front and back side ends - You have to push them inside to keep the cleanng blade away from the drum.
7. Remove the MCH assembley - 1 screw.
8. Remove the front separation claws + plate - 2 screws.
9. Remove the Drum Shaft
10. Replace the Drum
There are few details about how to manipulate a Drum - Do not touch the surface, do not expose it to intense light...
8.
Posted on Jan 12, 2009
FixinFax
  • 3085 Answers
SOURCE: kyocera 3035 printing all black pages
It sounds like you have a bad charge corona.
Posted on Jun 13, 2009
My kyocera taskalfa 180 do not print. operator can not find out any problem. he has checked major 3 unit.
All new copier/printer has safety pacageging SCREW /TAPES to prevent damage in traveling/shipping w/ it your Kyocera taskalfa 180 won't print, look for it and remove it all usually it is color orange 1 of them located at Optics unit .
Nov 21, 2014 | Kyocera Mita TASKalfa 180 Black Toner...
Low quality prinding copys
add new toner and do a drum refresh should fix it
Jan 31, 2014 | Kyocera TASKalfa 180 Copier
I have a kyocera 180 copier does not print texts even when we do internal print. it's blank when copying. We change DRUM, TONNER, DEVELOPER and MOTHER BOARD but still the same. Is there any other thing...
I have a kyocera 181 copier when we switch on the machine it showing error message " shake the toner container' kindly do the needful or send me service manual as soon as possible
I am awaiting for valuable response....
Sep 18, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing A2400 error please help.
c4200? a c4200 is a laser unit error. replace lsu.
Mar 30, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
HI there! Our Kyocera 180 does not photocopy documents. The paper that comes out is just blank. We recently replaced the tonner so we believe there's still enough ink. Should we checked if the photocopier...
if you are getting blank copies nothing on the page you need to check the drum main charge or the developer unit is locked into place correctly and if the developer unit is turning take out the developer unit and see if there is an even coating of dev and toner on the roller use a piece of paper rub of a small are on the developer roller put in the machine and do a copy after take out the developer unit and see if where you marked is visable if it is then the developer unit has a problem as it is not turning
Check the main charge roller it is connected to the side door
Feb 05, 2011 | Kyocera TASKalfa 180 Copier
281 people viewed this question
k24674
jasbo
jasbo
