Question about Mitsubishi Televison & Video
Mitsubishi television just replaced the projection lamp and now the tv shuts off 30-60 seconds after it is turned on, it powers self off
  • 38 Answers
After set shuts off, wait till the fans stop. Then press menu and input at the same time. The set will flash a 2 digit code. count the flashes. it could be a 2-6 or a 3-7 for example. then post that and that tells us where the problem lies.
Posted on Jan 01, 2014
4 Suggested Answers
  • 2920 Answers
SOURCE: TV shuts down
i would isend it to a shop and have them repair it
Posted on Oct 26, 2008
  • 1456 Answers
SOURCE: Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Posted on Jul 04, 2010
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
We have a mitsubishi 735 series tv. When we power it on the mitsubishi sign comes on then the tv shuts off. We replaced the lamp bulb but that wasn't the problem. Any suggestions
Most of these sets that come on with the blue screen and logo and shut off shortly after may have two resets---I can tell you the soft reset.
Turn set on with the Mitsubishi remote and when screen comes up blue with logo:
Menu, 1,2,3 enter
This applies to most of these sets.
Mar 14, 2012 | Mitsubishi WD-60735 Projection Television
Timer light comes on and off tv won't come on
it could be that you hav to reset the lamp timer on your tv, when you change the lamp on your tv you should also reste teh timer other wise the tv will think that you are still with your old lamp, and will turn the tv off when it has reached the designated time limit.
Jul 23, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi DLP TV model WD-65100. Power not ON
What about Lamp Fan if it is defective lamp will not turn on and if Ballast Board is not working then Lamp itself will not power on. Encompass has parts for this TV 1-800-638-3328
Feb 09, 2010 | Televison & Video
Tv was on and shut itself off. it now wont turn on. the green power light comes on then clicks off after 1 or 2 seconds with no picture ever coming on
The lamp is busted. Check and replace. Contact your dealer for lamp replacement information. Dispose the busted lamp properly. It contains mercury. Call your local authorities for proper disposal.
Aug 02, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Televison & Video Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
