Grey streaks across my computer monitor. Computer is dell dimension 8400. The monitor is a samsung syncmaster 923 nw.
Monitor is only 2 months old
  • Maikell Jocksan
    Maikell Jocksan Dec 30, 2013
    The picture you posted is too small. I don't see what you're referring to.
See attached . Four to follow. Grey streaks across my computer monitor.  Computer - 12_30_2013_9_06_53_pm.png
Posted on Dec 30, 2013
  • Thomas Dec 30, 2013
    If Monitor doesn't show grey streaks , it seems to be a Hardware or driver Problem of your Dell Pc. Then...
    1. Check all cable connections ( which Connection did You use?) for proper fitting.
    2. Check Video Card driver. Has to be the correct and most recent one.
    If that was okay, there was still the possibility, that
    3. the Video Card (if there is a dedicated one in your PC) is not plugged in respective Slot correctly anymore. ( To Double Check this, You Would have to open up the PC)
    4. or the Video Card is - maybe - defect.
    5. or you've Chosen wrong Resolution.
    Last but not least... There can also be an Interference Problem with the magnetic Field of another electrical Product Close to the Monitor as well as a defect cable....
    Unfortunately one does not know Details about the streaks (fixed or jumping).
    I apologize for any Typing fault. I'm answering by using my iphone..
    Greetings from Svitzerland,
    Thomas
    PS. This Fixya App is very uncomfortable to use with Iphone... Sorry for this "strange" reply.
    Thomas
4 Suggested Answers
antking
  • 51 Answers
SOURCE: monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Posted on Jan 03, 2009
  • 86 Answers
SOURCE: dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm
Posted on Jun 03, 2009
parrotheadpc
  • 2600 Answers
SOURCE: ABC diagnostic lights are green and D is yellow.
A,B,C green and D yellow is indicative of a component failure...in that the system cannot read a device it feels necessary to boot the machine such as a hard drive, floppy or cd/dvd drive. Power down the system, remove the power cord from the back, push the power button in for 10 seconds to bleed off the power. Remove and reseat all cables connecting the system devices. Remove all ram except for one stick and reboot. If you get boot, then try replacing the ram one stick at a time. If you still cannot boot though, try removing the cables from the devices and then plug in one a time until you get the machine to boot. If there is still a problem, the hard drive or its controller maybe the culprit.
Posted on Jun 14, 2010
Moritor turn off after 3 second
problem with power supply circuit or inverter and ccfl lamps..
May 17, 2010 | Samsung SyncMaster 920NW Monitor
Fluctution in samsung monitor
I'm going to take a shot in the dark here and say that by fluctuating you mean it's flashing and whatnot. This can be caused by the lamp dying.
As for the lines on the screen, those are probably dead pixels, which can happen to monitors.
Unfortunately, it isn't exactly cheap to fix a monitor, and you might be better off buying one.
To be on the safe side, try taking it somewhere like Best Buy to confirm what I've said.
Hope this helped :)
Nov 28, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Grey bands and shadowing
Uninstall the video driver from the Computer, restart the Computer then reinstall it. Furthermore, check for any updates for the video drivers.
You may also connect the monitor to any other normally functioning Computer to check if the lines remain there.
If it's so then the monitor requires servicing.
Nov 07, 2009 | Samsung SyncMaster 244T Monitor
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
Grey Band and Ghosts on monitor
check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
Jun 25, 2009 | Samsung SyncMaster 203B LCD Monitor
Dell dimension 8400 beeps 6 times monitor dosen't turn on
Jun 03, 2009 | Dell Dimension 8400 PC Desktop
Getting lines across the monitor screen
It may have one of reasons:
1. "Dirty" supplying voltage in the monitor - check all electrolytic capacitor.
2. Bad controller chip - check if it gets extremely hot when working, also you may see darkened area on other side of the PCB where that chip is located.
3. Loosed connection between controller PCB and the display itself - disconnect the cable and clean contacts, especially of blade connector on display side, check if there are some overpressed contacts.
Mar 07, 2009 | Samsung SyncMaster 910T-Black 19" LCD Flat...
I have a Samsung SyncMaster 913v Monitor - black streak forming
Plug your monitor into another computer, If the line persists, it is your monitor, you need a new one. If it does not, It is your Video card, you need a new one. But it is one of the other...
Feb 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Screen image seems to vibrate
it might be a joke program
restart your computer and comment if this helps.
Feb 04, 2009 | Samsung 943BWX Monitor
Computer Monitor Compatibilty
Dear nicktsa
You need to put either new dispaly card or AGP card in dell pc (it supports) to get proper resolutaion of monitor
thanks
Gizmo
Oct 15, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
