Question about Haier HDN455 Dehumidifier
Electrical Unit caused outlet to burn out When plugged into outlet with trip it trips it immediately after being plugged in
I believe it is highly likely you've got a short somewhere in your unit. The highest probability is that the cord is compromised. If that's not it, you could have bad winding insulation in the motor. It shouldn't be difficult to isolate the problem if you know your way around a multi-function volt/ohm meter.
Posted on Dec 28, 2007
I have had the Whirlpool GOld dehumidifier for 4 years. It was working great. Recently, I noticed that it stopped working. When plugged it, it trips my GFI socket. I have tried various outlets and checked...
Obviously, there is an electrical short within the unit. Should it be repaired? Yes, if you want continue using it. But, is the cost of troubleshooting, finding the necessary part and repairing it worth it? Most of the time, the cost to repair a dehumidifier is about the same, as what a new one would cost. Now, if purchased an extended warranty, when you originally bought the unit 4 years ago, then you're probably covered for the repair.
In the end, the decision is yours to make.
May 26, 2011 | Whirlpool Dehumidifiers
Dehumidifier has stopped working...it appears to be electrical..no switches are working and no lights are on.
Check the outlet that the unit is plugged into, to be sure that it's still has power. If it doesn't, a circuit breaker for that outlet may have tripped. Or the outlet receptacle may have a loose wire. Try plugging the unit into another outlet that is not on the same circuit, as the one it's currently plugged into.
May 23, 2011 | Dehumidifiers
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
I have two Haier HDN655E dehumidifier's. One works fine and the other wont come on. I have tried unplugging and plugged back in, hit the start button and nothing happens. Is there a reset switch or a...
Have you tested the outlet it's plugged into, to make sure it still has power? If it doesn't, check the circuit breaker panel in you home for a tripped circuit breaker. If there is one, unplug the dehumidifier, before resetting it. Then plug the dehumidifier back in. If the circuit breaker trips again, the problem is within the dehumidifier or the outlet is faulty (i.e. Loose wire, burned wire, broken outlet). If the outlet is not faulty, you should contact Haier America Parts and Repair 877-337-3639.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Apr 28, 2011 | Dehumidifiers
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
My Fedders A7DH45B2A dehumidifier (about 4 yrs old) continues to trip the fuse embedded in the outlet on the wall in which it's plugged in.. What gives??
either try a different outlet to see if the G.F.C.I. is bad on this outlet or if the dehumidifier trips on another line it could be the units motor start capacitor that shorted or the compressor is bad
Apr 06, 2010 | Fedders A7DH45B2A Dehumidifier
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
Aug 22, 2008 | Whirlpool AD65USL / AD65USM Dehumidifier
Runs, but overheated, tripped outlet causing freezer full of rotten food
There was a recall on these - it depends on the age.  I bought mine in 2003 or 2004, and they sent a repairman out to replace a circuit board.  Call Maytag to see if yours was in the recall.
Aug 09, 2008 | Maytag M7DH65B2A Dehumidifier
Ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Sep 07, 2006 | Whirlpool AD50USL Dehumidifier
Haier HDN455 Dehumidifier Logo
43 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
