Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
  • Anonymous Apr 01, 2014
    model lrfc25750sw
  • GE Master
  • 4,654 Answers
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
Ice build u p and leakage in freezer
you have a blocked drain in the freezer,when the machine goes into defrost the heater comes on and melts the frost off of the evaporator coil,the water melts and goes down the drain hose under the coil and leaks down to a drip pan near the compressor where it evaporates from the heat,your drain is blocked and the water is leaking onto the freezer floor and will drip out onto the floor,i use a steemer to blow out the drain line,shut down the machine or unplug it,melt out all the ice with hair dryer,depending on your model you might have to remove the back inside wall of the freezer to get at drain hole,you need something to push the **** out the drain hose,you can try a turkey baster or air from a compressor or a shop vac set it to blow,when you think it's clear pour a cup of hot water into the drain,if it drains down you're done if not keep hitting it with heat and air to push it through.
Sep 01, 2012 | Refrigerators
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Water leaks into freezer bottom & floor
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 16, 2009 | Kenmore Refrigerators
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
2,066 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
