Question about General Plumbing
Sump pump not pumping water properly
I have a GE sump pump that is supposed to pump water out that drains from our washer and sink. The pump acts like it's working, but the water isn't pumping out. Any suggestions?
  • 530 Answers
If your pump is turning then something is stopping the water from being removed. If you can see the pump check to see if the water is becoming turbulent when the pump kicks on? If the water doesn't appear to move or is moving only a little then either the pump impeller is damaged or the screen that keeps debris from entering the pump is clogged.
If it's never been cleaned it is most likely just a clogged filter screen. Clean it and it should work fine. If however the screen is clear then it is either a blocked line or a bad pump. And yes a pump can still run and not pump, if the impeller is bad.
Posted on May 22, 2009
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 | Dishwashers
Water is not completely draining, not even close. I've already checked the exit tubing and even found a pumpkin seed lodged near the pump hose. The float switch appears to be not working, I push it...
Hi... there might be a partial stoppage at the drain spigot under the sink check here. Then check in the sump of the dishwasher for any thing.... clean the filters. Otherwise the drain pump will have to be removed to ensure proper operation. good luck
Mar 01, 2011 | GE Dishwashers
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
Water isn't draining.
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Thanks for contacting fixya.com
Nov 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Portable Dishwasher wont drain GE Model #GSC3508K00WW
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.There's a few things you can look into that won't cost you any money.
Oct 26, 2009 | GE 24-7/8" Convertible Portable Dishwasher...
Dishwasher won't drain, the pump seems to be working but it's like it's clogged or something, any ideas?
OK, first using a sponge and bucket, drain out all the water of the dishwasher (DW) as you can. You can also use a towel too.
Check the discharge/drain cover at the bottom of the DW for any obstructions. Sometimes small pieces of all sorts of things get sucked into the drain port.
There should be a protective shroud/cover over the drain and you might have to remove a small hex head screw to get into the drain sump inlet. Some can be popped off without any tools.
Once you have the cover off, be VERY careful in probing the drain area trying to see if there are any small broken pieces of dishes or glasses that may have gotten into the sump area. You'll want to use a towel or sponge to get the water out of the sump area.
If you don't get anything out of the sump drain, it could be that the obstruction has worked its' way into the motor disposal impeller and you'll have to remove the DW from under the counter in order to get at the motor and pump assembly. This will require possible disconnection of the water supply line, AC power line or plug, and the drain line going to the sink or disposal.
Before getting into removing the DW, you can also check the drain line for blockage by disconnecting it from either the sink drain connection or disposal and blow into the line. If it's not clogged, you'll get air coming into the DW. If not, then the drain line is clogged. Also check the Air break connection, mounted on the sink, (if so equipped) and clean it out. You can also pour warm water down the Air break to verify that the line is clear.
If this doesn't work, please check my other solutions under dishwashers for a complete step-by-step for getting to the discharge pump section.
I've seen blockages occur fairly often on these models and it's usually caused by broken bits getting into the discharge pump and jamming the impeller. Once removed, normally the DW will work fine, unless the impeller has been totaly chewed up by the blockage, then you may have to replace the discharge impeller to get it able to pump out properly.
Hope you found this very helpful and best regards!
Aug 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
GE front loading washer not draining water
Something must have gotten into the drain pump. You drop the fromt panel on most of theses and open the pump sump, get the coin or whatever out of it.
Mar 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Not draining all the way
try unblocking the outflow pipes to the machine. The pump may be trying to pump the water out but the pipe might be blocked with debris i.e. hair/fluff etc... Look under the sink and you will see the outflow pipe attached to the sump (or u-bend) with a bowl or pot handy (because of excess water), take the pipe off of the sump and check for blockages. Then if you can check the u-bend too and see if this help.
Oct 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Plumbing Logo
495 people viewed this question
Top General Plumbing Experts
ka4iup
ka4iup
Gil Shultz
Marty Shuman
Marty Shuman
Are you a General Plumbing Expert? Answer questions, earn points and help others
